ECU
Old Sep 7, 2007 | 08:53 PM
NOman0608's Avatar
Default ECU
i have a 99 em1 with a b16a obd2 motor.
i bought a obd1 p28 with hondata s100 and obd 2 to obd1 conversion harness..
gave it to the shop to have a new chip putted in it and burn the chip to stock obd 1 b16a.
came home hooked it up.
i now have a check engine light. it idles good, but will not let me go past 4k rpms.
any ideas?
Old Sep 7, 2007 | 09:35 PM
doood's Avatar
been there done that
Default Re: ECU (NOman0608)
pull the code
Old Sep 7, 2007 | 09:54 PM
NOman0608's Avatar
Default Re: ECU (doood)
i took it to Advance, they cannot get the code...
i know theres a way you can do it by blinks, but i get confuse
Old Sep 7, 2007 | 10:26 PM
doood's Avatar
https://honda-tech.com/zerothread/1901557
Old Sep 8, 2007 | 04:14 AM
NOman0608's Avatar
i did the wire loop and borrowed my friends 2 pin connector.
No flashes whatsover.
You think it may be a bad ECU?
Old Sep 8, 2007 | 04:48 PM
Solster's Avatar
the ECU is Most Likely OK it's a BAD Chipping Most likely. if they Screwed up when thay chiped it then it won't go past 4K RPM. take off the top and cut the J1 Jumper Wire and see if it runs. if it does then it's fine and the Chip is Bad.
Old Sep 9, 2007 | 07:07 PM
NOman0608's Avatar
Default Re: ECU (Solster)
i cutted the J1 jumper.. the check engine is off and the car runs fine.
i notice the redline is like around 7600-7800.
i am running the GSR p28, could that be the reason?
also, what chip would you guys prefer to chip the p28 with the b16a motor.?
Old Sep 9, 2007 | 07:16 PM
serio_ENDLESS's Avatar
sorry but gsr are p-72 and p-28 are usually found in civics unless they went with a p-28
rhd98civic
12
Jan 15, 2010 11:21 AM
97ej6civic
Aug 14, 2009 03:46 PM
n*werk
24
Feb 26, 2009 06:06 AM
phat_gsr98
Jul 13, 2004 05:40 AM
2dark2bslow
Jan 27, 2004 02:15 PM
