CEL while driving, solid CEL, tried different ecu's, car drives fine but solid CEL stays
Old Sep 7, 2007 | 08:46 PM
n1_egsex's Avatar
* B A N N E D *
Default CEL while driving, solid CEL, tried different ecu's, car drives fine but solid CEL stays
it all started today when i was driving my car
94 civic with JDM ITR motor, using ITR engine harness and Rywire OBD1->OBD2A conversion harness into stock JDM ITR ecu.
The CEL would come on EVERYTIME i drive, not instantly, but give it about 1-2 minutes, and it'll come on, when it comes on, car drives fine still, no hesitation, no bogging, no stalling, idle is fine, vtec crosses over fine, it's like the car doesn't have anything wrong
when i go to pull the code, the car throws a solid CEL, from which i read, usually means bad ECU, so i take out the jumper harness and JDM ITR ecu, and i throw in my stock JDM P30 ecu meant for my B16A
i also reset the ecu by removing the ECU fuse under the hood and leaving it out for 10 minutes, before putting it back in
i drive around the block, keeping the revs under 3000 rpm, and sure enough, the light comes back on, i pull over, turn the car off, check the code, and solid CEL once again.
now here's the trip
-it can't be a bad ecu, since both ecu's are GOOD and car drives perfectly
-i doubt it's wiring, the only thing i've done was tap A4 to D6 for the vtec pressure switch trick
-engine harness is stock, untouched
-chassis harness is stock, untouched
does anyone know what the culprit could be? i dont notice any power loss at all, it's just driving me nuts
and no i'm not going to mask the problem by pulling the light bulb or putting electrical tape on the car, i want to FIX the problem
Old Sep 7, 2007 | 11:54 PM
crazyguy's Avatar
Default Re: CEL while driving, solid CEL, tried different ecu's, car drives fine but solid CEL stays (n1_egs
u can perform the CEL while the car is running.
Old Sep 8, 2007 | 04:22 PM
n1_egsex's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">u can perform the CEL while the car is running.</TD></TR></TABLE>
what do you mean?
Old Sep 8, 2007 | 04:24 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex &raquo;</TD></TR><TR><TD CLASS="quote">
what do you mean?</TD></TR></TABLE>
The trick in which to check what code its throwing, by watching its series of long and short blinks to determine it.
Old Sep 8, 2007 | 04:59 PM
DoWnfall's Avatar
http://www.jdmlyfestyle.com/ec...i.htm
see whats wrong and fix it?
Old Sep 8, 2007 | 07:36 PM
n1_egsex's Avatar
* B A N N E D *
i know how to check codes, i know how to read for codes, the thing is, when i plug the service connector, the CEL is supposed to blink, but in this case, it stays solid and doesn't blink at all
Old Sep 8, 2007 | 08:22 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex &raquo;</TD></TR><TR><TD CLASS="quote">i know how to check codes, i know how to read for codes, the thing is, when i plug the service connector, the CEL is supposed to blink, but in this case, it stays solid and doesn't blink at all</TD></TR></TABLE>
strange, have you tried bringing it to a place that can plug into it and get a reading?
rick_rabies
Engine Management and Tuning
Aug 24, 2009 06:22 PM
TurboBA8
Feb 20, 2007 07:25 AM
liquidxEG
Feb 22, 2005 03:46 PM
h8tred
Jul 7, 2003 08:35 PM
