help with headbolts...
Old Jun 15, 2002 | 09:53 PM
the DR.'s Avatar
Default help with headbolts...
https://honda-tech.com/zerothread?id=209171
if anyone has any insight onto this please help..
thanks in advance
Old Jun 16, 2002 | 06:12 AM
Rocket's Avatar
Default Re: help with headbolts... (CIVICtypeS)
If bolts are stress beyond their yeild strength plastic deformation occurs and the bolt wlll no longer spring back(have clamping pressure). That could be why your bolts were loose.
Repeated tighten and loosening work hardens the bolts and your bolts will lose it's elasticity (clamping ability). You know you have this kind of trouble when you torque down your bolts using a torque wrench and the bolts can never reach specified torque (They just keep turning).
[Modified by Rocket, 3:12 PM 6/16/2002]
Old Jun 16, 2002 | 01:19 PM
g2teg's Avatar
Default Re: help with headbolts... (Rocket)
This is true, but it is also a good way to snap off bolts inside your block(pain in the a$$). Another way to tell if your bolts are too stressed or streched is to try to fit the threads of the bolts together. ex. L7 That way you will be able to see if they have streched. The slightest difference will cause the threads not to fit and will give you problems down the road.
D16SohcVtec
Jun 4, 2008 03:52 AM
CivicK20
Nov 11, 2006 06:03 PM
crispydee
Jan 9, 2005 01:17 AM
H22coupe
Apr 30, 2004 05:24 PM
2muchPSI
Dec 29, 2002 09:19 AM
