1988 sedan build
Old Sep 7, 2007 | 07:22 AM
the13thround's Avatar
Default 1988 sedan build
this is the first motor i have ever built and really the first motor i have worked on more then just some maintnance like fluids and ****.
its going in a 88 4dr civic DX.
pictures:
d16a6 w/ delta 272 cam (completely stock A6 head)
-fully stripped and tanked with new gaskets
vitara pistons 76mm
legend h-beam rods arp bolts
block posts
micropolished crank and ACL bearings all around
ARP headstuds
cometic MLS headgasket
*60/48 t3 from t-bird, rebuilt by me
*egay blurr manifold w/high temp paint job
*DSM 450cc injectors
255 lph fuel pump
chipped pr4 running BRE
colder spark plugs NGK
also an Si tranny with centerforce clutch and 11 lbs flywheel
*only for a little while till i get more money for real ramhorn, t3/t4, and RC injectors.
motors in here are some new pics, hopefully will be done this weekend.
wideband display
roofing mastik filled mounts,
ghetto tech
more of my beer induced fabricating fuckups, o2 bung is covered by the crossmember and the wastegate flange is off a 1/8" or so. ill have pics of how i fixed this up soon.
fixed o2 problem
tig welded lower pipes
hot side
just barely clears now
i should have a vw lip to finish off the front soon.
Modified by the13thround at 11:26 AM 9/7/2007
Old Sep 7, 2007 | 07:29 AM
4doorcivic16's Avatar
looks good amn but why did you cut half the bumper out?
Old Sep 7, 2007 | 09:09 AM
EDwEFprts's Avatar
Default Re: (4doorcivic16)
cool to see that your trying it yourself.
i want an '88.
any more pics of car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4doorcivic16 &raquo;</TD></TR><TR><TD CLASS="quote">looks good man but why did you cut half the bumper out?</TD></TR></TABLE>
Old Sep 7, 2007 | 09:56 AM
EFinawesomeman's Avatar
Default Re: (EDwEFprts)
not a bad setup my friend. I always enjoyed those turbo manifolds for some reason. what suspension mods are you gonna be going with? gotta put that power to the ground!
Old Sep 7, 2007 | 10:07 AM
90sedan's Avatar
Default Re: (EFinawesomeman)
Why not just buy a traction bar to help give you room for the Dp and remove the gangster lean of the radiator? You'll want it anyways to help reduce your wheel hop down the line anyways.
But none the less, its always nice seeing another boosted ef 4door.
Old Sep 7, 2007 | 10:12 AM
Default Re: 1988 sedan build (the13thround)
as you can see this is ghetto rigged, if i had money for a traction bar i would have bought one, im going to fab one up when i can afford the materials, as for suspension all i have now are my koni/nuespeed setup. i filled all the motor mounts to gain some traction. ill have pics of the car when its done, and if you have ever put a 3 inch core intercooler on an ef i think you will realize why the bumper had to go, i wasnt going to leave like a couple of scraps on it and have it look like ****.
Old Sep 7, 2007 | 10:24 AM
I under stand I put a 3 inch wide intercooler on a 92 accord and the bumper had to take a big ol' hack job. I'd like to see you fab a traction bar thatd be pretty sweet.
Old Sep 7, 2007 | 01:23 PM
JKGONZALEZ3's Avatar
Default Re: 1988 sedan build (EFinawesomeman)
looks good but thats alot of bumper missing.
Old Sep 7, 2007 | 02:40 PM
90sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the13thround &raquo;</TD></TR><TR><TD CLASS="quote">as you can see this is ghetto rigged, if i had money for a traction bar i would have bought one, im going to fab one up when i can afford the materials, as for suspension all i have now are my koni/nuespeed setup. i filled all the motor mounts to gain some traction. ill have pics of the car when its done, and if you have ever put a 3 inch core intercooler on an ef i think you will realize why the bumper had to go, i wasnt going to leave like a couple of scraps on it and have it look like ****.</TD></TR></TABLE>
Although, i was able to fit a 3.5 thick core IC behind my bumper by just cutting the bumper support and the grill out. Did you modify the bumper support at all?
Old Sep 7, 2007 | 03:08 PM
bigluelok's Avatar
looks good
Old Sep 7, 2007 | 03:18 PM
Danronian's Avatar
Great HMT build.
Old Sep 7, 2007 | 03:29 PM
EFing_bmxED's Avatar
dang thats gonna look sik wit a lip. mk3 gti lip?
Old Sep 8, 2007 | 06:51 AM
im going to fill in the opening with expanded metal and paint it black, yeah i cut the support in half and welded angle on to hold the intercooler in place. i suppose i could have pushed the intercooler back more but it would be really close to the downpipe and turbo.... expletive it i dont care just want to get this **** runnin.
redlinetuning
Oct 17, 2008 08:13 AM
boostedek9
Oct 14, 2006 07:36 PM
turboeg77
Apr 14, 2006 06:44 AM
Bartman201
Oct 5, 2005 10:15 AM
1337 Si
Jul 1, 2002 08:40 AM
