'05 CRV HVAC Control Bulb
it's a fun one. you need to remove the pocket above the panel (pop off the acess cover in the back of the pocket, remove the screw, pull the pocket towards you. remove the two screws that hold the unit in and pull it out. the bulbs are "half screw" type and are pretty simple to replace
Changing the bulb was straight forward. You have to tug on things a little once you remove the screws. Bulb is a specialty bulb I assume only available through Honda? That's were I got mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott in MN »</TD></TR><TR><TD CLASS="quote">I assume only available through Honda? That's were I got mine.</TD></TR></TABLE>
Pretty safe bet. The aftermarket ones never seem to fit right.
oddmut
Honda Civic (2001 - 2005)
17
Feb 11, 2020 09:15 AM
Jettplane
Jun 12, 2012 08:28 AM
Tomek
Oct 5, 2002 05:46 AM
