~~climate control console~~
Old Nov 13, 2004 | 05:55 PM
DOHC-ter AMIEL's Avatar
Default ~~climate control console~~
does anybody know how to take it off so i can change the light bulb? mine burnt out.
Old Nov 13, 2004 | 06:30 PM
Default Re: ~~climate control console~~ (AMIEL)
bump
Old Nov 14, 2004 | 09:33 PM
CRZY_INTEG's Avatar
Default Re: ~~climate control console~~ (DOHC-ter AMIEL)
yea. first of all under the glove box u need to first remove the ac wire. then remove the hazzard & defogger buttons. u need to use a small flat head screw driver after that there are 2 screws taht u need to remove after that it will just pull out.
Old Nov 15, 2004 | 10:13 PM
Default Re: ~~climate control console~~ (CRZY_INTEG)
is it 1 bulib to light everything or is it separate bulbs cause i wanna cahenge the bulb to red to match mr radio buttons is that possible?
Old Nov 17, 2004 | 10:25 PM
CRZY_INTEG's Avatar
there r 4 different blubs two for the top and 2 for the bottom
Old Feb 26, 2005 | 10:02 AM
yangrou8's Avatar
can anyone specifically describe how to remove the hazard/defog buttons to access the two screws? i removed the buttons but only the covers came off and i tried prying out the switches from the bottom and they wont come out. so frustrating....
Old Feb 26, 2005 | 11:10 AM
supersonicblue's Avatar
Default Re: ~~climate control console~~ (yangrou8)
theres a slit on the bottom of each button where you can stick a flathead into.
put it in, hold the button down with your thumb and pry
Old Feb 26, 2005 | 12:18 PM
yangrou8's Avatar
Default Re: ~~climate control console~~ (supersonicblue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supersonicblue &raquo;</TD></TR><TR><TD CLASS="quote">theres a slit on the bottom of each button where you can stick a flathead into.
put it in, hold the button down with your thumb and pry</TD></TR></TABLE>
i just tried that.. no luck and im startin to damage the plastic around the switch. anyone else have any ideas?
EDIT: got them out.. just had to pull hard. hehe
Modified by yangrou8 at 10:01 PM 2/26/2005
Old Feb 26, 2005 | 01:57 PM
LSvtec03's Avatar
wrap some masking tape around the screwdriver when you remove stuff like that to prevent damaging stuff.
AznBlueBoy
Jun 13, 2011 03:47 PM
I LUV MY EJ1
Oct 21, 2008 08:37 PM
Dekorum
Jun 29, 2008 10:06 AM
Scott in MN
Sep 26, 2007 06:25 AM
EKtypeRhaTcH
Jul 8, 2003 10:55 AM
