car wont go pass 2700RPM!!!!
Old Sep 6, 2007 | 10:07 PM
s0flyy56's Avatar
Default car wont go pass 2700RPM!!!!
so yah i have a JDM B16 that i just swapped in like 2 months a go and for some reason i tried to take of REGULAR at a light and i couldnt go pass 2700 rpms...
i just got done runnin open headers and i think thats the reason...
and btw its a OBD 1 converted to OBD2 SiR b16 in a 98 EK hatch runnin a OBD2a ITR ecu
help....PLEASE!!!!!
Old Sep 7, 2007 | 03:54 AM
pauley_lsvtec's Avatar
Default Re: car wont go pass 2700RPM!!!! (s0flyy56)
i had the same problem about two mounths ago and it has nothing to do with running open header mine was accompanied by a check engine light that stayed on solid when the jumper was jumped to read it it had a fried resistor in the ecu which was caused by one of the vtec wires rubbing on the fire wall and shorting out the ecu check it out i wouldent be suprised if it was similar to your situation.
Old Sep 7, 2007 | 12:25 PM
s0flyy56's Avatar
Default Re: car wont go pass 2700RPM!!!! (pauley_lsvtec)
bump it didnt work
any more idea's???
Old Sep 7, 2007 | 12:37 PM
delsol456's Avatar
you dont happen to have lanch control do you?
Old Sep 7, 2007 | 01:03 PM
cB7KiD's Avatar
do you have any check engine lights?? if so your car is in limp mode
kitt
May 30, 2018 08:17 AM
Dual_Phart_cans
May 1, 2005 08:12 AM
EF-21
Mar 16, 2004 09:45 PM
phatcivic99
Jun 27, 2002 04:37 PM
BeavisB16
May 20, 2002 07:37 PM
