where is the shift interlock located? auto to manual swap
Old Sep 6, 2007 | 08:49 PM
jdmhondamotive's Avatar
Default where is the shift interlock located? auto to manual swap
i just got done doing the auto to manual swap and the key stays in the ignition when i try to turn the key off, my friend said that i needed to take off the shift interlock or something, is that true or not true, if so where is it at?
Old Sep 6, 2007 | 08:55 PM
89s1's Avatar
Default Re: where is the shift interlock located? auto to manual swap (jdmhondamotive)
you need to push in on the key to get it to turn the last little bit.
the shift lock is for the auto trans to be able to take it out of park without a key in the ignition. Really just for tow truck drivers and stuff. and to answer your question it is a little slit that fits a key just off to the side of the PRND bezel.
I hope this helps, because if it doesn't I really dont have a damn clue what you're talkng about.
Old Sep 6, 2007 | 09:04 PM
Street Racer X's Avatar
Default Re: where is the shift interlock located? auto to manual swap (89s1)
Its part of the automatic trans shifter assembly, It has to be gone if you have the manual shifter in or else your shifter wouldnt fit. You have to solder a couple of wires together as well to take care of the ignition part of it. The link below will tell you which wires you need to solder together.
http://members.aol.com/jrmupzaii/auto2man.html
Old Sep 7, 2007 | 06:21 AM
blah13's Avatar
Default Re: where is the shift interlock located? auto to manual swap (whitecivichatch90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitecivichatch90 &raquo;</TD></TR><TR><TD CLASS="quote">Its part of the automatic trans shifter assembly, It has to be gone if you have the manual shifter in or else your shifter wouldnt fit. You have to solder a couple of wires together as well to take care of the ignition part of it. The link below will tell you which wires you need to solder together.
http://members.aol.com/jrmupzaii/auto2man.html</TD></TR></TABLE>
Yup, in an automatic theres a switch in the shifter to tell the ignition the car is in park and to light up the red P in your gauge cluster. Otherwise you cant remove your keys. My dx auto is a pain in the *** to drive during the winter becuase even when its in park, the P light wont light up for a minute or two so I cant get my keys out.
JGTW
Jan 8, 2019 07:58 AM
LeegodaEG
May 6, 2013 10:28 AM
m0squ1t0
16
Sep 17, 2009 11:06 AM
srt4pilot
May 28, 2009 03:02 AM
consolidatedbord
Jan 28, 2005 02:08 PM
