Auto to Manual Trans
Old May 5, 2013 | 08:09 PM
LeegodaEG's Avatar
Icon6 Auto to Manual Trans
Is it possible to make an automatic a manual transmission?
If not, how do I know if my car has a shift kit on it because in order for it to shift smooth, I have to do it myself starting from 1 and it doesn't shift to D4 (even if I put the shifter there) unless I'm over 50mph.
Unless my trans is taking a dump on me..
Little help over here?
Old May 5, 2013 | 09:18 PM
xile6's Avatar
Default Re: Auto to Manual Trans
Your cant turn an auto into a manual.
And your auto is probably going out.
Old May 6, 2013 | 05:58 AM
LeegodaEG's Avatar
Even if I swapped the auto trans for a manual?
And it shifts fine when I do it myself it doesn't keep slamming into gear. I understand what you're saying and I had that experience before with one of my previous cars. I don't think it's the same thing.
Old May 6, 2013 | 10:20 AM
xile6's Avatar
you can do an auto to manual swap.
your need everything from the manual tho.
Old May 6, 2013 | 10:28 AM
JuggerNaut-CTR's Avatar
pedal assembly
clutch master cylinder
trans
clutch/flywheel kit
shift linkage
ecu
trans mount
Unless the parts can be had for dirt cheap, its not worth the time, money, effort. Might as well start with a manual car.
rice a roni
23
Sep 30, 2022 02:12 AM
andyz
Dec 9, 2013 08:40 PM
Jackie Wallace
Transmission & Drivetrain
Mar 10, 2013 04:23 PM
ChangT
May 26, 2011 07:16 PM
Jdm91Teg
Mar 30, 2005 02:46 PM
