Replacing wheel studs
Does anyone know how to replace wheels studs. One of my studs snapped off and acura is trying to charge $180 to replace a $4 stud. From what I understand you have to pull the hub assembly off because there is not enough room for the studs to come out or to put i new ones with out doing so. If anyone has a better solution please let me know. THanks
Once my friend was working on his suspension and was hitting the nuckle with a rubber hammer and accidentally got one of the studs loose. Then he put a bolt on it and got it tight again.
So you can hit it until it gets loose and then remove it
There used to be a thread on here about replacing wheel studs. I think it still exists on some alternate resources, let me see if I can find a link.
[edit] I see you've already gotten your answer over at the other place
Bertsch911
May 18, 2012 06:15 AM
HKSuperSi
Sep 13, 2007 11:05 PM
Tokyo_X-treme_Racer
Jul 20, 2004 08:10 AM
Drinker
