Replacing wheel studs
Old Sep 6, 2007 | 07:19 PM
rpc08's Avatar
Default Replacing wheel studs
Does anyone know how to replace wheels studs. One of my studs snapped off and acura is trying to charge $180 to replace a $4 stud. From what I understand you have to pull the hub assembly off because there is not enough room for the studs to come out or to put i new ones with out doing so. If anyone has a better solution please let me know. THanks
Old Sep 6, 2007 | 07:24 PM
JjuuN R's Avatar
Default Re: Replacing wheel studs (nos86)
Yeah, go somewhere else to get it replaced, do new wheel bearings while you're at it...
Old Sep 6, 2007 | 07:57 PM
SiR99's Avatar
Once my friend was working on his suspension and was hitting the nuckle with a rubber hammer and accidentally got one of the studs loose. Then he put a bolt on it and got it tight again.
So you can hit it until it gets loose and then remove it
Old Sep 6, 2007 | 08:16 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Replacing wheel studs (SiR99)
There used to be a thread on here about replacing wheel studs. I think it still exists on some alternate resources, let me see if I can find a link.
[edit] I see you've already gotten your answer over at the other place
Old Sep 7, 2007 | 06:40 AM
rpc08's Avatar
what kind of car was he working on where the stud got knocked loose? also front or back wheels
Bertsch911
May 18, 2012 06:15 AM
piotrush
Honda Civic (2006 - 2015)
18
Jul 4, 2009 08:31 PM
SlowB16
Jun 11, 2008 07:00 AM
HKSuperSi
Sep 13, 2007 11:05 PM
Tokyo_X-treme_Racer
Jul 20, 2004 08:10 AM
