JRSC ITR w/particular build questions
Old Sep 6, 2007 | 05:11 PM
Andrew Sutherland's Avatar
Default JRSC ITR w/particular build questions
Hey guys. Does anyone see any striking issues with the following setup?
b18c5 w/190,000 kms - rebuilt at 170,000 and dyno tuned - runs strong
skunk2 forged valves, retainers, springs (clay tested for clearance)
skunk2 pro stage 2 cams <--- I heard this could be an issue?
spoon adj cam gears (set properly)
jdm itr pistons
new metal headgasket
JR supercharger @ 7.5 psi
hondata intake gasket
walbro 255 fp
440 cc injectors
fuel pressure regulator and gauge
chipped w/Crome engine management and tuned properly on a dyno
Thanks in advance for any constructive comments
Old Sep 6, 2007 | 06:27 PM
CRVRX's Avatar
Default Re: JRSC ITR w/particular build questions (Andrew Sutherland)
I wouldn't run those cams, too much overlap. GST intake , Type R Exhaust is the best combo we have found to date.
Old Sep 6, 2007 | 07:49 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: JRSC ITR w/particular build questions (CRVRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't run those cams, too much overlap. GST intake , Type R Exhaust is the best combo we have found to date.</TD></TR></TABLE>
thats what they said on turbo applications, and people have proved them wrong. but a blower setup is a lot different. depending on where the power is made with the jrsc yes they may hurt you. or they may be great. but setup looks good.
Old Sep 6, 2007 | 09:18 PM
Veris's Avatar
Default Re: JRSC ITR w/particular build questions (boostedcivicsir)
John knows what he is talking about!
Turbo's are not boost limited like an eaton blower. If you could make 15+psi with them then large duration cams might help out.
Case in point. ITR cams make less hp then the gsr/itr combination with a JRSC.
BoostinEJ1
Oct 15, 2007 05:24 PM
9civichatch3
12
Sep 6, 2007 06:03 PM
CivicEG6-R
Nov 3, 2005 08:44 AM
SneezR
Apr 3, 2005 02:02 PM
SOHCVTECx2
Sep 20, 2003 11:53 AM
