B18C swap - crank sensor problems
Old Sep 6, 2007 | 05:03 PM
aznlaoboi315's Avatar
Default B18C swap - crank sensor problems
I'm swapping in my B18C1 from my 97 GSR into my 98 EX and I ran into a problem. The crank sensor plug on my EX harness has a 3-Wire plug and my GSR has a plug only 2-wires. I have the female end that connects to the GSR crank sensor but I'm not sure if i need to do some rewiring or just do a CFK bypass trick. any help would be greatly appreciated. thanks
Old Sep 6, 2007 | 05:21 PM
Murk 'EM's Avatar
Default Re: B18C swap - crank sensor problems (aznlaoboi315)
will the crank sensor fit from the ex? if so just put that sensor in the block... i dont see why it wouldent fit, there both honda
Old Sep 6, 2007 | 05:29 PM
mckrank313's Avatar
Default Re: B18C swap - crank sensor problems (95_acc0rd)
i used the cfk trick because my motor has no crank sensor (obd1 motor obd2 car) and it works fine... so unless you feel like repinning you could just do it this way take no time at all
incase you didn't find it http://technet.ff-squad.com/ckftrick.htm
Old Sep 6, 2007 | 06:25 PM
Default Re: B18C swap - crank sensor problems (mckrank313)
since my motor has a crank sensor would i run into any problems if i just left the crank sensor disconnected and perform the cfk trick? the thing with obd1 motors is they don't have a crank sensor what so ever. so I'm just making sure I wont run into any problems if i go and do this. thanks for the inputs btw
Old Sep 8, 2007 | 03:14 PM
so with the crank sensor unhooked will i run into any problems?
Old Sep 8, 2007 | 03:28 PM
geebs's Avatar
Default Re: (aznlaoboi315)
itll throw a cel..
do you have the engine harness from the gsr? depin the civic crank pos sensor connector wires and depin the gsr ones.. swap the gsr connector to the civic harness.. match the two wires.. and cut/tape the third to the harness.. its unneeded..
Old Sep 8, 2007 | 04:30 PM
pdiggitydogg's Avatar
just run the bypass trick...it does work
Old Sep 8, 2007 | 04:36 PM
sicones's Avatar
Default Re: (pdiggitydogg)
just swap on the 2 pin plug from your GSR harness, disregard the black wire and just match the colors
Old Sep 9, 2007 | 02:45 PM
Default Re: (sicones)
yeah i have a gsr harness. i think im gonna depin the plug and match the colors. havin a crank would probably be better then by-passing it. thanks for the help guys i appreciate it.
Old Sep 9, 2007 | 02:59 PM
zerovandez's Avatar
Just match the blue and white wires. Disregard the last wire.
Thategguy94
Feb 7, 2015 01:15 PM
jjmcmana
Nov 1, 2008 09:02 AM
blowbyu24
Jan 12, 2007 10:54 PM
FOMULA91
Nov 17, 2005 10:33 PM
