changed water pump and messe with timming...IDLE and lowd clacking sound.
Old Sep 5, 2007 | 10:24 PM
mustang5.slow's Avatar
* B A N N E D *
Default changed water pump and messe with timming...IDLE and lowd clacking sound.
hey guys i recently changed my water pump and when i was done i put my timing belt on and it was properly timed. cause my tensioner wasn't hooked up right.
now when i turn the car on after sitting and cooling down it goes from 2000 to 0 RPM's. and its is at Zero it makes a nasty metal to metal sounding clash sound...BUT it only does it when i freshly tun the car on. after it is on and going. it idles a little bit. and it does not make that sound any longer after warmed up.
should i stop driving the car until i get a expert to look at it or is it fine to drive the 3/4 of a mile daily.
is this something i can fix my self??
Old Sep 6, 2007 | 04:36 AM
RyanA's Avatar
Default Re: changed water pump and messe with timming...IDLE and lowd clacking sound. (mustang5.slow)
Well, I"m just taking a shot in the dark but I'm thinking whenever you hear metal to metal, it's not OK to drive your car. Get it checked out unless you are moneybags and can just afford to replace your engine after a catastrophic failure...
Ryan
Old Sep 6, 2007 | 07:29 AM
* B A N N E D *
Default Re: changed water pump and messe with timming...IDLE and lowd clacking sound. (RyanA)
damn. i didn't wanna hear that.
but does anyone have any idea why this is. and why it stops when the warms up alittle bit??
Old Sep 6, 2007 | 07:31 AM
Probot's Avatar
seems like something is too tight at cold start up and stretches out once its warm - as for the metal sound...dont know. take it to a mechanic before something bad (or worse) happens
Old Sep 6, 2007 | 07:37 AM
themikewoo's Avatar
id it coming from the head or the bottom end.
if head id check rockers
if bottom end id take it apart and see if some bearings are gone
Old Sep 6, 2007 | 07:38 AM
* B A N N E D *
Default Re: (themikewoo)
i think that it comes form the head and from the intake side.
Old Sep 6, 2007 | 08:13 AM
Syndacate's Avatar
It may be just a valve tick...or you may have bent one (or more) of the valves.
Old Sep 6, 2007 | 05:30 PM
* B A N N E D *
Default Re: (Syndacate)
if so what is normally done in these cases.??
GoodEyeSniper
Apr 10, 2010 04:28 PM
fryman
Aug 22, 2008 10:31 AM
Ge-money
Sep 6, 2006 02:55 PM
90YellowRex
16
Mar 9, 2006 11:13 AM
jefe
10
Aug 18, 2004 12:47 PM
