Tranny shifting question
Old Sep 5, 2007 | 04:07 PM
BoostinEJ1's Avatar
Default Tranny shifting question
Basically one day I was driving to wash my car and all of a sudden third gear would not engage. Naturally I tried to put it in gear a few times and nothing, just out of the blue it would not engage. What I noticed today while pulling my motor out is that one of the two T-bracket bolts going into the motor was missing and the other was extremely loose. My question is would this cause third gear to not engage? I did notice that with the car of or at a stop the car would go into third for the most part with no trouble at all. So it kind of makes sense to me at least that when the car was in motion the motor was moving and third gear was having trouble lining up. My only reason to think this may not be the problem is because wouldn't this happen to every gear? I did notice that night when trying to get home that every gear was getting a little harder to find... The motor and tranny a JDM ITR if it really makes a difference and the car it was in was a 99 Si. Thanks for your time.
Old Sep 5, 2007 | 04:10 PM
gsxr1k05's Avatar
if the trans was sitting at a really bad angle it could. i did an auto2man swap on my 90 crx, and it shifted had as expletive. but when i swapped in the b series with hasport mounts, it shifted like a stock car would. so i would say that trans angle has a lot to do with how hard it is to shift.
Old Sep 5, 2007 | 05:13 PM
SHG_EasyE's Avatar
Default Re: (gsxr1k05)
bump hopefully that is the problem!
Old Sep 5, 2007 | 05:59 PM
BoostinEJ1's Avatar
anyone else?
Old Sep 5, 2007 | 06:14 PM
Thateguhate's Avatar
Default Re: (FBP_EM1R)
i would drop the tranny to look at the clutch and flywheel.
Mine did this in every gear... took it down and looked at it only to find that the pressure plate, clutch and flywheel were all bad. (NOT LIKE YOU THINK) the clutch had meat, but everything was worn down halfway.... as in an angle... finally the pressureplate could no longer operate the clutch and flywheel causing it to lock up suddenly.
I still never figured out why. everything was new except the flywheel (it was resurfaced)
I now replaced it with the same stage 2 exedy clutch, but bought a new fidanza lightweight flywheel as well.. works great.
I did do an auto to manual but im not positive thats what the problem is, i have an innovative conversion mount so it should be sitting correctly.
Old Sep 5, 2007 | 06:17 PM
f22beast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 &raquo;</TD></TR><TR><TD CLASS="quote">if the trans was sitting at a really bad angle it could. i did an auto2man swap on my 90 crx, and it shifted had as expletive. but when i swapped in the b series with hasport mounts, it shifted like a stock car would. so i would say that trans angle has a lot to do with how hard it is to shift.</TD></TR></TABLE>
Absolutly. Put the bolts in that bracket
Old Sep 5, 2007 | 08:56 PM
BoostinEJ1's Avatar
Default Re: (Thateguhate)
clutch only had like 1000 miles on it but ill be pulling the tranny off tomorrow. wish i could put the bolts back in but the motor is now out of the car and im looking to sell the tranny and i want to let the buyer know what may be wrogn with the tranny, if anything at all.
Old Sep 6, 2007 | 03:50 AM
BoostinEJ1's Avatar
Default Re: Tranny shifting question (FBP_EM1R)
ttt for some more help.
Old Sep 6, 2007 | 06:44 AM
BoostinEJ1's Avatar
ttt
Old Sep 6, 2007 | 07:51 AM
SHG_EasyE's Avatar
bump, i think i may pick this up and give it a try
Old Sep 6, 2007 | 10:10 AM
BoostinEJ1's Avatar
will be pulling the tranny off the motor tonight to verify
Old Sep 6, 2007 | 10:49 AM
gsxr1k05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thateguhate &raquo;</TD></TR><TR><TD CLASS="quote">i would drop the tranny to look at the clutch and flywheel.
I did do an auto to manual but im not positive thats what the problem is, i have an innovative conversion mount so it should be sitting correctly.</TD></TR></TABLE>
auto2man swap shouldn't be the problem. it might be the start of the bad angle, but thats on us for using stock mounts. especially junk yard ones that have over 100,000 miles on them...
Old Sep 8, 2007 | 09:16 AM
BoostinEJ1's Avatar
a friend of mine is coming to pick this tranny up today, anymore ideas before he takes it. i guess he is willing to take a chance and if its sometihing else he will just fix it but just looking for anymore ideas...
Old Sep 8, 2007 | 09:18 AM
SHG_EasyE's Avatar
bump for anymore input, im thinking it was due to the motor moving way to much b/c of that rear mount
whiteciv88
Jan 25, 2008 02:41 PM
95turbodteg
Honda Civic (2006 - 2015)
Dec 6, 2006 05:44 AM
cvc323
Jul 29, 2004 03:07 PM
BLaCk-S
Mar 15, 2004 05:48 PM
