Vtec controller
I hooked up my vtec controller and my throttle percentage is backwards. when I floor it it goes to 0 when I let off it goes to 100
Does anyone have an idea why?
I have a pm6 ecu I have the gray wire running to c7 at the ecu witch is a red and blue wire
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef-hatchcrap »</TD></TR><TR><TD CLASS="quote">I hooked up my vtec controller and my throttle percentage is backwards. when I floor it it goes to 0 when I let off it goes to 100
what type of vtec controller are you using?
i'll assume its an apex-i vafc. if that's the case, did you follow the instructions to floor the gas pedal so that the tps would read the proper reading before starting the car up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef-hatchcrap »</TD></TR><TR><TD CLASS="quote">Nope I didnt do that is there a way to reset it and do it again.
I dont have the instructions for the vafc 2
yes, there is a reset mode or something. i dont recall from memory, as its been years since i had one of these things.
but you can still download the instructuons from apex-i's website.
my question to you is, why are you installing this thing if you dont know how it works?
there are countless warnings that apex prints everywhere about engine damage and whatnot if installed incorrectly or improper tune.
</TD></TR></TABLE>yes, there is a reset mode or something. i dont recall from memory, as its been years since i had one of these things.
Well I had one about 4 years ago with my last single cam.
I know how to use it its just been awhile but I got it all figured one of the settings were backwards runs alot better now.
[626] SiRJKwIcK89Ef
27
Oct 10, 2001 03:33 PM
