no spark obd1 motor in obd2 car
Old Sep 4, 2007 | 05:28 PM
vtecftw's Avatar
Default no spark obd1 motor in obd2 car
as stated above an obd1 d series in an obd2 car with obd2 harness. Ecu conversion harness with custom wired dizz using this schematic. I am not getting spark but the motor is turning over.
This is ths schematic i used
all wires are hooked up but the two for the top dead sensor ( green and green)
because there was only one green leading from the dizz but no green from the harness. Could someone please helpme solve my problem.
Thank You
Old Sep 4, 2007 | 05:39 PM
vtecftw's Avatar
comeonguys!
Old Sep 4, 2007 | 05:44 PM
vtecftw's Avatar
comeon guys!
Old Sep 4, 2007 | 05:47 PM
saleensolution's Avatar
Default Re: (vtecftw)
are you sure the coil and ignitor is good?
Old Sep 4, 2007 | 05:57 PM
vtecftw's Avatar
yes the motor was taken out of a friends car
that was running 100%
no CEL's either
Modified by vtecftw at 7:20 PM 9/4/2007
Old Sep 4, 2007 | 06:20 PM
vtecftw's Avatar
up up
Old Sep 4, 2007 | 06:25 PM
gourley's Avatar
When i wired up a OBD1 dizzy to a obd2a car i just matched the wire colors up and wired togeather. worked fine for me, no CEL's
Old Sep 4, 2007 | 06:38 PM
vtecftw's Avatar
alright well my ignitoris getting power and still no spark. I am going to try and give it a try your way wiring them color to exact color but it doesnt seam they all correspond.
Old Sep 4, 2007 | 08:08 PM
USDMCIVICHATCH's Avatar
what year and trim is your car?
Old Sep 4, 2007 | 08:48 PM
inspector01's Avatar
Check the resistance on your ignitor, it should be between 12.x-16.x i think, i just pulled out one that was at 10.x and put a new one in and it was good.
The other problems is likely that the diagram has the CKP+ and the CYP+ wires switched, if you switch those 2, it will fire right up.
Old Sep 5, 2007 | 03:39 AM
vtecftw's Avatar
its an 00 dx
inspector i will give that a try when i am off work and let everyone know, any other suggestions?
soon2bdropped
Aug 30, 2007 10:32 AM
lVlemphizStylez
Feb 16, 2007 07:15 AM
1man
Jul 21, 2003 11:45 AM
B18C1 '96 Coupe
May 21, 2003 02:25 PM
