Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Civic / Del Sol (1992 - 2000) (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/)
-   -   no spark obd1 motor in obd2 car (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/no-spark-obd1-motor-obd2-car-2088864/)
vtecftw 09-04-2007 05:28 PM
as stated above an obd1 d series in an obd2 car with obd2 harness. Ecu conversion harness with custom wired dizz using this schematic. I am not getting spark but the motor is turning over.
This is ths schematic i used
https://img103.imageshack.us/img103/...kzmqzmxmw0.jpg
all wires are hooked up but the two for the top dead sensor ( green and green)
because there was only one green leading from the dizz but no green from the harness. Could someone please helpme solve my problem.
Thank You https://honda-tech.com/forums/images/smilies/emthup.gif
vtecftw 09-04-2007 05:39 PM
comeonguys!
vtecftw 09-04-2007 05:44 PM
comeon guys!
saleensolution 09-04-2007 05:47 PM
Re: (vtecftw)
are you sure the coil and ignitor is good?
vtecftw 09-04-2007 05:57 PM
yes the motor was taken out of a friends car
that was running 100%
no CEL's either
Modified by vtecftw at 7:20 PM 9/4/2007
vtecftw 09-04-2007 06:20 PM
up up
gourley 09-04-2007 06:25 PM
Re: (vtecftw)
When i wired up a OBD1 dizzy to a obd2a car i just matched the wire colors up and wired togeather. worked fine for me, no CEL's
vtecftw 09-04-2007 06:38 PM
alright well my ignitoris getting power and still no spark. I am going to try and give it a try your way wiring them color to exact color but it doesnt seam they all correspond.
USDMCIVICHATCH 09-04-2007 08:08 PM
Re: (vtecftw)
what year and trim is your car?
inspector01 09-04-2007 08:48 PM
Check the resistance on your ignitor, it should be between 12.x-16.x i think, i just pulled out one that was at 10.x and put a new one in and it was good.
The other problems is likely that the diagram has the CKP+ and the CYP+ wires switched, if you switch those 2, it will fire right up.
vtecftw 09-05-2007 03:39 AM
its an 00 dx
inspector i will give that a try when i am off work and let everyone know, any other suggestions?
