About to install Skunk2 Pro-S Coilovers..have questions
if its full coilovers you dont need anything from the original assembly so you dont need a spring compressor. take teh assembly out put the new one in.
As long as your kit came assembled then yes. If you ordered a new kit I doubt the coil sleeves are assembled. If not, then a spring compressor will be required. You should get it anyway. It makes taking the oem springs off much easier.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">As long as your kit came assembled then yes. If you ordered a new kit I doubt the coil sleeves are assembled. If not, then a spring compressor will be required. You should get it anyway. It makes taking the oem springs off much easier.</TD></TR></TABLE>
All_JDM_Si
Sep 29, 2003 11:00 PM
