98+ spec jdm type r still stuck with CEL
Old Sep 4, 2007 | 01:55 PM
alien's Avatar
Default 98+ spec jdm type r still stuck with CEL
i just put in a brand new second o2 sensor, the first one close to the headers was still in tact, however the check engine light is not coming off and still unable to crack vtec, anyway to reset the computer? or could i be missing something else, i also took it to auto zone and couple of other shops to do a diagnoses but none of the computer were able to even establish a connection .... any suggestions? it is a really really nice motor bought from Hmo
Old Sep 4, 2007 | 02:12 PM
dmorris05's Avatar
Default Re: 98+ spec jdm type r still stuck with CEL (alien)
and this has what to do with an 01-05 civic?
Old Sep 4, 2007 | 03:52 PM
1llmatic's Avatar
New User
Default Re: 98+ spec jdm type r still stuck with CEL (dmorris05)
disconnect your battery to reset the ECU. You need to disconnect it for a few minutes.
If the CEL comes back you didn't fix the problem. There is a way to check the CEL as well by jumping the ECU. Its probably in the FAQ for the integra forum.
like the person said above this is the 01-05 civic forum.
Old Sep 10, 2007 | 06:28 AM
KaBlookie's Avatar
Default Re: 98+ spec jdm type r still stuck with CEL (1llmatic)
Pull your ECU codes using this tutorial and post up what code(s) it's throwing.
1freshEM1
Sep 8, 2010 11:18 AM
OUtlAWdb8
Jan 5, 2009 01:39 PM
peanut butter
Jan 10, 2008 09:48 AM
alien
Sep 8, 2007 11:03 AM
denshu
Dec 16, 2003 02:48 PM
