Cel problem????
Old Dec 21, 2008 | 02:53 PM
OUtlAWdb8's Avatar
Default Cel problem????
i have a cel problem with 98 jdm itr motor. when its on car shoot out white smoke and wont rev pass 4k rpm. but when the car is warmed up it goes away and drive normally. tried jumping wires to troubleshoot cel codes but cel light does not blink any codes. Can anybody HELP PLEASE??!!!
Old Dec 21, 2008 | 02:55 PM
93turbo16's Avatar
Default Re: Cel problem????
It would be a HUGE help if you would tell us what car/motor you are working with...
Old Dec 21, 2008 | 03:16 PM
OUtlAWdb8's Avatar
thx... its a 98 jdm itr
Old Dec 21, 2008 | 07:30 PM
mouab18c1's Avatar
so u have a CEL but when jumping it, it does not blink? are you jumping it correctly?
Old Dec 21, 2008 | 07:52 PM
93turbo16's Avatar
What ecu are you running and what year car is it??
Old Dec 21, 2008 | 08:39 PM
OUtlAWdb8's Avatar
P28 in a 95 acura integra
Old Dec 21, 2008 | 08:40 PM
OUtlAWdb8's Avatar
Im pretty sure i am... the abs light blinks but not the CEL
Old Dec 21, 2008 | 08:42 PM
93turbo16's Avatar
Does the check engine light come on and stay on when you turn the key to the on position?
Meaning when you turn it to where you hear the fuel pump prime and the main relay click?
If so.. then it should flash when you jump the service connector under the passenger side dash.
If you jump the connector and the CEL does not flash.. then you are getting a solid CEL. This points to a malfunction in the ecu. Replace it with another known working ecu.
The limiter at 3500 RPM is limp mode. It is running off the back up processor in the ecu.
Old Dec 21, 2008 | 11:29 PM
SOHC_4dr's Avatar
your using the D16z6 OBD 1 ecu to controll your B18C OBD 2. the ecu is your issue. its the wrong one! you need the P73.
Old Dec 22, 2008 | 09:03 AM
mouab18c1's Avatar
actually..it depends if it is chipped for his motor or not...
Old Dec 22, 2008 | 11:03 AM
OUtlAWdb8's Avatar
That is exactly the problem Im having when I turn the key to the ON position...Thanks!!
Old Dec 22, 2008 | 11:04 AM
OUtlAWdb8's Avatar
the ECU is chip
Old Dec 22, 2008 | 12:09 PM
SOHC_4dr's Avatar
the ECU is chip
is it done right? i think it would be a bigger hassle trying to get that ecu to run a B18C. you may have to get it tuned better to fix rev when cold. or just get the proper ecu
Old Dec 22, 2008 | 12:58 PM
mouab18c1's Avatar
as long as it is burned with the right base map then it will not be a problem..i have a p28 with itr base map..runs awesome...try switching your tps and map sensor plug..just in case u got them in the wrong ones....also try cleaning the tb where your map senosor is mounted to...
Old Dec 25, 2008 | 09:08 PM
EK9_K2@'s Avatar
the ecu is chipped correctly it is tuned for the motor it was running fine in his car before and in my car he got the motor and ecu from me we just got another ecu so we will see if thats the problem
Old Dec 27, 2008 | 09:31 PM
OUtlAWdb8's Avatar
the ecu u got from chad was bu bu... get me another 1
Old Jan 3, 2009 | 09:58 PM
ctr_ek209's Avatar
did my ecu work??
Old Jan 5, 2009 | 01:39 PM
OUtlAWdb8's Avatar
Originally Posted by ctr_ek209
did my ecu work??
YES YES...find out why the ECU you got is faulty....the problem comes and go...
honda_aus87
Mar 26, 2011 08:01 PM
LaOXXKIDD
Aug 22, 2009 05:42 AM
skUnK2jdm
26
Feb 7, 2008 10:08 AM
CRXified
Jul 30, 2005 01:31 PM
