Looking for a high flow turbo filter. See what is happening to mine inside
I have a K&N air filter on my gt30.
Looking for something that flows better than this.
The gt30 is sucking so much air it is concaving the filter..
See pics here:
See pics here:
Just curious, how how does it get under your hood? one of my buddies had that happen to his in his 240SX with SR20 and it was more because of the heat that was generated that made it brittle and weak. Once the underhood temps were corrected, no more problems. Also with K&N
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">Just curious, how how does it get under your hood? one of my buddies had that happen to his in his 240SX with SR20 and it was more because of the heat that was generated that made it brittle and weak. Once the underhood temps were corrected, no more problems. Also with K&N</TD></TR></TABLE>
I would think the OP could build a cold air box for that filter to keep heat away, maybe a custom hood scoop too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTeg95 »</TD></TR><TR><TD CLASS="quote">Are you sure the engine isnt moving at higher rpms and causing it to rub against the hood? </TD></TR></TABLE>
i heard geoff saying that k&n were giving him problems b/c overtime they wouldn't last as long. and he recommended green filters, i know a few people on clubrsx.com had been using them w/ no problems. i also got one too here are some pics of mine.
http://performanceparts.com/part.php?partID=190605
anyone try the new x-stream filters?
I've never seen a K&N do that as a result of it being sucked in like that, was the filter new when you put it on? I've seen filters get bent on something, once the metal screen around the filtration material gets bent then it will loose it's shape easier.
From: "That one guy with that one car" Kennewick WA
^^nice call. like a soda can, once its been damaged on its side thats going to be its weak point therefore making it easier to crush.
have you tried a filter the shape of a perfect sphere? that should be the most structerly sound IMO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">I've never seen a K&N do that as a result of it being sucked in like that, was the filter new when you put it on? I've seen filters get bent on something, once the metal screen around the filtration material gets bent then it will loose it's shape easier. </TD></TR></TABLE>
That filter has less than 500 miles on it, it was pefectly new when i got it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_dc_fan »</TD></TR><TR><TD CLASS="quote">my k&n is holding up great, but my gt30 is only seeing 17psi. try using a shorter filter, seems like it would be more structerly sound.
This filter is a 4" K&N? You don't happen to have the part number for this filter, do you?
I've been having a hell of a time finding a filter short enough to fit.
Thanks
</TD></TR></TABLE>This filter is a 4" K&N? You don't happen to have the part number for this filter, do you?
Thanks
oranginal
Mar 14, 2008 04:20 PM
