so i bought a cb radio for my civic
Old Sep 4, 2007 | 12:10 PM
zeBRAHz's Avatar
Default so i bought a cb radio for my civic
i know it doesn't make much sense but i just wanted one to mess around with. but the problem is, i have no idea where to connect the wire in my fuse block. i know it needs to be somewhere where it only gets power when the ignition is at acc or on but still, i have no idea where i would connect the wire to do that. any help would be appreciated
Old Sep 4, 2007 | 12:11 PM
zeBRAHz's Avatar
Default Re: so i bought a cb radio for my civic (zeBRAHz)
oh and it's a 2000 civic ex
Old Sep 4, 2007 | 12:15 PM
instructor74's Avatar
oh dear god no but to each their own try tapping off the fuse for the radio that should be a switched source
Old Sep 4, 2007 | 12:22 PM
97Ej6mike's Avatar
If all else fails, just make your own on/off switch for it. Im not a CB radio expert, but you should be able to just directly connect it to the battery, the ****, when turned all the way down, should turn off the unit. At least the older ones do.
Old Sep 4, 2007 | 12:36 PM
zeBRAHz's Avatar
Default Re: (97Ej6mike)
i'd rather just connect it to the fuse box somehow because there's no reason for me to go through all the trouble of wiring this thing like i would an amplifier
Old Sep 4, 2007 | 12:40 PM
97Ej6mike's Avatar
Default Re: (zeBRAHz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeBRAHz &raquo;</TD></TR><TR><TD CLASS="quote">i'd rather just connect it to the fuse box somehow because there's no reason for me to go through all the trouble of wiring this thing like i would an amplifier</TD></TR></TABLE>
Thats just lazy, thats what that is .
lol jk.
Have you tried maybe direcly splicing it into your 12v cig adapter? Those arent hard to pop out, lil bit easier IMO tan trying to wire it into the fuse box if you are uncertain of how to do that.
Old Sep 4, 2007 | 12:46 PM
sniggler316's Avatar
This thread has the fuse panel diagram: https://honda-tech.com/zerothread?id=1966666 I would try connecting to the ACC free pin at the top of the fuse box
That's #3 at the top BTW
Old Sep 4, 2007 | 01:07 PM
zeBRAHz's Avatar
Default Re: (sniggler316)
wow i'm still confused. that diagram just confused me more than i already was. i've never worked with the fuse panel before so bare with me...
Old Sep 4, 2007 | 01:08 PM
zeBRAHz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">
lol jk.
Have you tried maybe direcly splicing it into your 12v cig adapter? Those arent hard to pop out, lil bit easier IMO tan trying to wire it into the fuse box if you are uncertain of how to do that.</TD></TR></TABLE>
i would, but dont have a soldering iron
Old Sep 4, 2007 | 01:35 PM
pdiggitydogg's Avatar
Old Sep 4, 2007 | 04:47 PM
Default Re: (pdiggitydogg)
Number 3 at the top of the above diagram is the ACC free pin. Put a quick disconnect on the power wire for your CB and plug it in there.
Old Sep 4, 2007 | 05:40 PM
vtecftw's Avatar
wow come on
its a positive a negative and a antenna!
Old Sep 4, 2007 | 05:44 PM
Murk 'EM's Avatar
Default Re: (vtecftw)
ground it.. and take the power and put it to the windshild wiper fuse.. should be a 15amp just wrap the wire around one of hte fuse ends and put it back in.... it sounds rigged but thats the easiest way to do it (and the way professional install shops do it.. i workd at one so i know)
Old Sep 4, 2007 | 05:59 PM
Default Re: (95_acc0rd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_acc0rd &raquo;</TD></TR><TR><TD CLASS="quote">ground it.. and take the power and put it to the windshild wiper fuse.. should be a 15amp just wrap the wire around one of hte fuse ends and put it back in.... it sounds rigged but thats the easiest way to do it (and the way professional install shops do it.. i workd at one so i know)</TD></TR></TABLE>
Please DON'T do this!^^^^^ WTF shop did you work at? I bet there are a lot of pissed off customers...
Old Sep 4, 2007 | 06:22 PM
fatpride111's Avatar
ive though about putting a cb radio in my car for the hell of it... lemme know if u get it workin. i got a 93 eg and i might think about doing the same thing ur doing.
Old Sep 4, 2007 | 07:02 PM
DCSportEJ1Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
those are all blank spots to tap into. you wont need to steal power from anything which imo is not a good idea. i would still suggest runnin an inline fuse.
Old Sep 4, 2007 | 07:14 PM
vestalfootball72
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sniggler316 &raquo;</TD></TR><TR><TD CLASS="quote">
Please DON'T do this!^^^^^ WTF shop did you work at? I bet there are a lot of pissed off customers... </TD></TR></TABLE>
If you have so much knowledge in this field, why not offer some instead of just wasting space on here??
To the OP - How Wire up a CB radio (or anything that needs 12v switched power)
Remove radio-
OEM - http://www.installdr.com/Insta...5.pdf
Aftermarket- remove using the 2 keys supplied when you purchased it, or consult manual
on the back of the radio, there will be a harness.
if its aftermarket, find the following wires
1. Red (Switched power
2. Black (Ground
if its OEM, find the following wires
1.yellow/red (switched power)
2.Black (ground)
Your going to tap into these wires- in order to do so, either go out and buy a soldering iron for 10 dollars, solder for 3, and a roll of tape
or
buy some t tap connectors
http://www.discountcarstereo.c...D=530
and there you have it, run the wires, zip tie them down nice and secure, and bolt everything back up.
Old Sep 4, 2007 | 07:49 PM
Default Re: so i bought a cb radio for my civic (vestalfootball72)
Wow, way to read dood. He said he wanted to go to the fusebox and I told him where to look.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sniggler316 &raquo;</TD></TR><TR><TD CLASS="quote">This thread has the fuse panel diagram: https://honda-tech.com/zerothread?id=1966666 I would try connecting to the ACC free pin at the top of the fuse box
That's #3 at the top BTW</TD></TR></TABLE>
Number 3 at the top of the above diagram is the ACC free pin. Put a quick disconnect on the power wire for your CB and plug it in there. </TD></TR></TABLE>
Modified by sniggler316 at 9:05 PM 9/4/2007
Old Sep 4, 2007 | 08:45 PM
vestalfootball72
Guest
Posts: n/a
Default Re: so i bought a cb radio for my civic (sniggler316)
reading&gt; me
jdm 1080p
16
Sep 3, 2012 10:08 PM
hatchinprogress
Mar 1, 2012 03:30 PM
lazyweasal4
Audio / Security / Video
Dec 12, 2006 04:06 PM
swiftstyles
Oct 18, 2004 05:18 AM
ej1 pilot
Jun 6, 2004 08:55 AM
