stripped bolt stuck. need help
Old Sep 4, 2007 | 09:38 AM
jonathan13's Avatar
Default stripped bolt stuck. need help
ok i was trying to install my rear camber kit for my ek, and i go to take out the two bolts going to the chassis and one is stripped and will turn and turn but never come out. ive tried using a crowbar to pry against it so there will be pressure while im pulling it out and maybe come out but its hard to find a place to pry on. so my question is does anyone have in wonderful ideas on how to get this sob out or should i just go to the shop and have them cut it, drill it, and re-tap the hole with a bigger bolt? any help is greatly appreciated. thanks in advance.
Old Sep 4, 2007 | 05:28 PM
jonathan13's Avatar
Default Re: stripped bolt stuck. need help (jonathan13)
ttt. ever happened to anyone?
Old Sep 4, 2007 | 05:32 PM
drtysohc's Avatar
sounds like the nut that is welded to the inside of the subframe broke loose. you'll have to cut and access hole in the subframe, weld the nut back, then weld the subframe back up...it's a big job, but I had to do it on my hatch.
vtecftw's Avatar
cut the head off
drill it out
put a bigger bolt with nut
grade8 only
Old Sep 4, 2007 | 05:35 PM
ke98248's Avatar
Default Re: (vtecftw)
I had a similar problem:
https://honda-tech.com/zerothread?id=2086467
Try using a bolt extractor first.
Old Sep 4, 2007 | 06:14 PM
jonathan13's Avatar
appreciate everyones imput i believe my best bet since its stripped will be to do drill it out and re-tap it which i will probably take it somewhere and spend a half a million dollars to do it because i do not trust myself to not screw up. but again thanks everyone
Old Sep 4, 2007 | 06:16 PM
ke98248's Avatar
TRY USING A BOLT EXTRACTOR FIRST. It's only like $2 to try it!
Old Sep 4, 2007 | 06:28 PM
jonathan13's Avatar
Default Re: stripped bolt stuck. need help (ke98248)
how exactly does it work? im thinking it probably wont help. the bolt is spinning freely its just not backing itself out. i mean i can wedge it and twist on it for about an hour and it will come out maybe 1/4 of a millimeter.
Old Sep 4, 2007 | 08:02 PM
ke98248's Avatar
They come with directions.
Old Sep 4, 2007 | 08:12 PM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">TRY USING A BOLT EXTRACTOR FIRST. It's only like $2 to try it!</TD></TR></TABLE>
IF THE WELD NUT ON THE BACK SIDE HAS BROKEN LOOSE, EVEN TRYING TO DRILL IT WILL JUST KEEP SPINNING THE WELD NUT.
if that is the case, you need to cut it off, cut an access and re weld a new nut, or go oversize. a drill / extractor is like a left hand screw that is designed to have a hole drilled in the fastener, and the extractor either hammered into it, it is the small coarse extractor and turned c.c.w. to remove the fastener. or like the snappy matco extractor, it is long and left handed also, it is designed to be turned into the drilled fastener removing it.
but again, if it is just spinning in the hole, chances are the weld nut is broken loose. and will probably not work.
Old Sep 5, 2007 | 07:21 AM
jonathan13's Avatar
Default Re: stripped bolt stuck. need help (boostedcivicsir)
i can tell that the welded not is not broken loose because it will get tighter like its caught threads and then loose again when it hits the stripped threads and goes back in a little bit.
Old Sep 5, 2007 | 07:41 AM
Mr. Badwrench
try to cut the bolt head off, drive the remnants through the back side, and oversize it. and let it eat.
UserX826
10
Feb 21, 2009 10:02 PM
rhennin
Suspension & Brakes
12
Apr 12, 2007 12:16 PM
kyorishin
Apr 11, 2006 11:02 PM
sohc00
Mar 22, 2004 05:15 AM
Batoutahell
Oct 15, 2002 04:33 AM
