EX cluster won't light up...
Old Sep 4, 2007 | 07:22 AM
Aarron_M's Avatar
Default EX cluster won't light up...
Swapped an EX cluster this weekend into my DX hatch. Revs work fine, turn signals work, all the sensor lights work...but no light around the guages at night? I checked the fuse, and it's fine. I read something about the dimmer switch, but never got a response from someone with this same problem. Any thoughts?
Old Sep 4, 2007 | 07:33 AM
instrument's Avatar
» Search Results
Your search for dimmer switch returned 22 results.
Old Sep 4, 2007 | 10:14 AM
Aarron_M's Avatar
Default Re: (instrument)
I did the search. Nothing was confirmed in any of the threads, except there's a dimmer bypass. I'm not interested in that. The last thread I posted in on this subject, I was told to start a new thread, instead of bumping that one.
Old Sep 4, 2007 | 10:21 AM
Lasty K's Avatar
Weird. I swapped a EX cluster into my DX and all was fine. It was nice and bright.
Old Sep 4, 2007 | 10:27 AM
mckrank313's Avatar
Default Re: (Lasty K)
where did you get the cluster from? are all the bulbs there are or are any of them burnt out?
if you say the cluster is working but not lighting up check the bulbs... (you said you checked the fuse and it doesn't sound much like the dimmer switch but could be you could play with it..._)
Old Sep 4, 2007 | 12:57 PM
Aarron_M's Avatar
Default Re: (mckrank313)
The cluster's only got 93,000 miles on it, and is in great shape. I'll be wiggling the dimmer switch when I get home tonight. Hope that works.
Old Sep 4, 2007 | 01:41 PM
crxricer66's Avatar
Default Re: (STImachine)
i had the same prob. it is a junk dimmer switch. i jus cut the red and black wires on back and hook them together until i get another switch. gl
Old Sep 4, 2007 | 08:37 PM
Mr Knee's Avatar
thats weird. when mine went out i just pulled the fuse an popped i back in an it lit up nice and bright.
Old Sep 5, 2007 | 11:27 AM
Aarron_M's Avatar
Default Re: (Mr Knee)
OK, so I did the dimmer elimination mod, and still no lights. What's next to check? The bulbs? What did you guys do with the ground wire, when you connected the red and black wires?
Old Sep 5, 2007 | 11:41 AM
ennah's Avatar
My lights in my cluster went out, i changed the fuse and when i connected the black and red wire on the dimmer switch and plugged it back in and the lights now work
Old Sep 5, 2007 | 05:28 PM
Aarron_M's Avatar
Default Re: (ennah)
Lemme make sure I'm reading this correctly. Cut the red and black, connect them. Reinstall the dimmer switch, with the ground still hooked up to it, and that should do it?
Old Sep 5, 2007 | 05:43 PM
I heart my Honda.'s Avatar
I'd just replace all of bulbs if I were you. That's what was wrong with my EX cluster when I got it.
Old Sep 6, 2007 | 03:23 AM
Aarron_M's Avatar
Default Re: (I heart my Honda.)
Guess that's my next step.
Old Sep 8, 2007 | 06:03 AM
Aarron_M's Avatar
Replaced the bulbs, nothing still. The climate control lights are also out. Makes me think it's some sort of grounding issue. Any more ideas?
85_305
Honda Civic (2001 - 2005)
11
Jun 26, 2009 10:10 AM
90civicgsr
Dec 16, 2007 07:34 AM
redline5th
Apr 23, 2007 07:40 PM
Digithalgravel
Jul 14, 2006 11:07 PM
American.Graffiti
Aug 27, 2005 07:53 PM
