nitrous on h22 in a eg
Old Sep 3, 2007 | 06:05 PM
LSLIMEZ's Avatar
Default nitrous on h22 in a eg
i sprayed nitrous on a h22 in a 92 hb and it started to bog and then it threw a check engine light on for a fuel injectors code 16 i had my fuel injectors tested and clean i have a walbro 255 fuel pump and i have a adjustible fuel pressure regulator on it i want to know why does this keep happening?
Old Sep 3, 2007 | 07:14 PM
2point2's Avatar
Default Re: nitrous on h22 in a eg (LSLIMEZ)
punctuation man...
Are you running a resistor box for the injectors?
Old Sep 3, 2007 | 10:29 PM
LSLIMEZ's Avatar
Default Re: nitrous on h22 in a eg (2point2)
yes
Old Sep 3, 2007 | 11:18 PM
Rd91SiB18ls's Avatar
How much nitrous and how much timing.
What do the plugs look like.
Old Sep 4, 2007 | 02:27 PM
LSLIMEZ's Avatar
Default Re: nitrous on h22 in a eg (Rd91SiB18ls)
its a 50 shot, and i retart the timing 2 degrees
Old Sep 5, 2007 | 01:53 PM
LSLIMEZ's Avatar
i'm sure someone had this probablem before.
Old Sep 6, 2007 | 03:13 PM
DxTrix's Avatar
Is this a single foger wet kit? Did you by chance mix your jets?
live2ride31
Feb 4, 2007 07:39 PM
Myh4tch
Sep 15, 2004 04:57 AM
-Midnight-
Oct 23, 2003 10:44 PM
willyboyK20
Mar 19, 2003 05:20 AM
soler
Sep 5, 2001 10:33 AM
