CEL 23 after driving
Old Sep 3, 2007 | 11:33 AM
flatblack-h22's Avatar
Default CEL 23 after driving
OBD2 GSR, OBD1 Harness, P72
92 SI Hatch
okay i recently wired up the knock sensor to D3 and the cel went away. but after driving for awhile and the car warms up, it throws a cel. but if i turn the car off then back on its goes away for a moment and comes back.
Old Sep 3, 2007 | 12:08 PM
duggy's Avatar
Either the knock sensor is bad, your wiring is trash, or the knock sensor is doing it's job.
Old Sep 3, 2007 | 12:32 PM
serio_ENDLESS's Avatar
get the ecu chipped they will disable it for you
Old Sep 3, 2007 | 01:38 PM
ke98248's Avatar
Default Re: (serio_ENDLESS)
That will only mask the problem, not solve it
Old Sep 3, 2007 | 07:41 PM
ALSO IF THE WIRE YOU RAN INTO YOUR ECU IT HAS TO BE FULL CONNECTION SUCH AS BEIND SOLDERED THE BROKEN WIRE MAY SENS A WRONG SIGNAL OR ITS DOING ITS JOB
Old Sep 3, 2007 | 08:55 PM
yoffer's Avatar
Banned
no need to yell^^ expletive caps lock!
Powered By Garrett
Mar 30, 2008 12:05 PM
s_vares
Sep 3, 2006 02:54 PM
petarr
Mar 4, 2006 10:37 AM
shatchi
17
Feb 1, 2005 10:00 AM
