what do i need to reff a jdm b18b???
its a jdm b18b out of a jdm 94 integra. has the rywire adaptor harness already. the motor is complete and running. i know that i will need a new cat converter on there already since mine is bad. let me know what parts i will need to put in in order for me to california reff this motor into my crx!!! thanks and hope you guys can help me out here.
i know the motor will have to run obd1 and have the usdm equivalent of the obd1 ecu for that motor. You will also need all smog equipment that came on that motor in the us. Above that i am not sure but somebody else should know
doesnt matter what type of headers you use... manifold ya just need one with a purge valve on the back...and yes you will need to buy the jumper for the ecu and the dizzy plugs what I did when I reffed my b16 rywire good buy...
na they never asked me where I bought it if they do run it should go back to HMOmotors cause they have to have it on records on each motor the sell
hey i have a 87 civic si im putting a 89tegbottom-end with a 87teg head port polished what will be the problem with the wiring if theres any
mynameizstitch
Sep 3, 2007 10:02 PM
mynameizstitch
Sep 3, 2007 09:43 PM
AkiraDrift
Sep 19, 2004 07:28 AM
