black smoke coming from behind my car
Old Jun 14, 2002 | 09:56 PM
redteg1's Avatar
Default black smoke coming from behind my car
i was driving down this one road today when a friend following behind me told me there was black smoke that came out from my exhaust and just from underneath the car in general not only the exhaust only when i took it up into the rpms. wat could this be??
[Modified by redteg1, 6:57 AM 6/15/2002]
Old Jun 14, 2002 | 10:01 PM
Mr. Softee's Avatar
Default Re: black smoke coming from behind my car (redteg1)
rings or running rich.
Old Jun 14, 2002 | 10:02 PM
samagon's Avatar
it is more than likely an optical illusion (although if you have an exhaust leak maybe not) that it looks like it is coming out from under your car.
it is not uncommon for integras (or hondas in general) to run very rich when they are in the higher RPMs at WOT. the black smoke is a result of it running rich, it is unburned hydrocarbons.
if you are really worried about it, get a full tune up (plugs, wires, rotor, cap, injector clean, and TB clean) and take it to a dyno, get a wideband O2 test with a dyno, to see what your AF ratios are like at WOT in high RPMs.
mine is sitting at about 12.5:1 at WOT in the higher RPMs, this is normal, and it belches black smoke.
you shouldn't worry about it too much.
if you start seeing blue smoke, or white smoke, that is something to worry about.
Old Jun 15, 2002 | 12:53 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: black smoke coming from behind my car (samagon)
That happens on all cars the at wot and you shift to the next gear. Its either you runnning semi-rich or the carbon build up blowing out.
art
Old Jun 15, 2002 | 07:59 AM
redteg1's Avatar
Default Re: black smoke coming from behind my car (Arturbo)
oh ok..i didn't thinik it would be anything serious either....thanx for the info guyz
Old Jun 15, 2002 | 02:26 PM
PaChiLa Leader's Avatar
did you do OBD1 conversion
me and friend's did on OBD2V2 tegs
and all found out that OBD1 makes teg running rich especially when floor it
Old Jun 16, 2002 | 09:08 AM
redteg1's Avatar
Default Re: black smoke coming from behind my car (PaChiLa Leader)
i originally have obd1
kodarren
Sep 14, 2006 07:44 PM
crawlin
Jul 24, 2006 01:30 PM
suckanut
10
May 14, 2005 04:10 PM
InfamousRS
May 23, 2002 01:17 PM
echo999
Jan 12, 2002 03:43 PM
