SRS light
Old Sep 2, 2007 | 12:56 PM
94allmotor's Avatar
Default SRS light
got a 00 civic the srs light is on and the steering wheel is completely off..last owner said he was in a hurry and half-assed the install. and my horn doesnt work either...anyways to reset the srs light im also taking off the steering wheel to make the it straight
Old Sep 2, 2007 | 12:57 PM
BlueIntegraBoy's Avatar
Default Re: SRS light (94allmotor)
What are you asking now?
Old Sep 2, 2007 | 12:58 PM
94allmotor's Avatar
my 00 civic srs light is on..last owner installed the steering wheel and its 45 degrees off so the H is point to the left..
Old Sep 2, 2007 | 01:34 PM
AWD: Jeff's Avatar
Default Re: (94allmotor)
depends what year the car is, if it has dual or single airbag
dual airbag there will be a yellow plug connector that plugs into the underdash fuse box... it plugs into a dummy connector. you need a jumper or paper clip to conect to the end to reset. there are certain timed steps u will need to take.
or single airbag, the reset connector will be on the opposite side, which is your passanger side. it will be plug again to a dummy connector. again there are certain timed steps u will need to take.
certain timed steps: ie: srs light blinks, etc
Old Sep 2, 2007 | 02:04 PM
Well, to reset the light, search "SRS reset"
Old Sep 2, 2007 | 06:25 PM
94allmotor's Avatar
Default Re: (MOB: Jeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MOB: Jeff &raquo;</TD></TR><TR><TD CLASS="quote">depends what year the car is, if it has dual or single airbag
certain timed steps: ie: srs light blinks, etc</TD></TR></TABLE>
i got a 00 civic ...timed steps?
Old Sep 2, 2007 | 06:47 PM
kevinz's Avatar
or you could the yellow conector out of the back of the cluster to disable the srs light, I have no air bags now though. to each his own. GL
Old Sep 2, 2007 | 07:19 PM
94allmotor's Avatar
that would disbale the airbags?
Old Sep 4, 2007 | 01:52 PM
AWD: Jeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94allmotor &raquo;</TD></TR><TR><TD CLASS="quote">
i got a 00 civic ...timed steps?</TD></TR></TABLE>
theres srs procedures
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94allmotor &raquo;</TD></TR><TR><TD CLASS="quote">that would disbale the airbags?</TD></TR></TABLE>
in order to disable the airbags, unplug the battery. wait at aleast about 5 min. get a torx screw driver, one on each side remove airbag. passenger side if u need too. to disable the airbags, you need to completely take out the whole srs system. shown here.
remove srs light in cluster.....remove this piece off of cluster.
AmauryR
Dec 22, 2011 02:43 AM
thewrai6th
Jan 15, 2009 05:28 PM
steam
Sep 5, 2007 08:17 PM
english-seth
Nov 20, 2006 02:56 AM
