logged turbo back presure at 32 psi boost!
was out testing last weekend, i run a b16a, stock head,cams,and valves, t3 60-1 turbo charger, tial 38mm waste gate, and at 32psi boost its making close to 60psi presure in the exhaust manifold!
the back presures not bad until it goes over 7500rpm then it just climbs!
the turbocharger runs a 0.63 a/r turbine and a stg3 t3 turbine wheel....
any suggestion on how to reduce back pressure with out effecting my power band!
rev limiter is set at 9300rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">try a 44mm or larger wastegate?</TD></TR></TABLE>
more like a larger exh wheel and housing.
what exh manifold are you using ?
what cams are you using ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetlude »</TD></TR><TR><TD CLASS="quote">what do you use to measure back pressure in exhaust manifold? </TD></TR></TABLE>
a sensor
0-150 psi.
a sensor
0-150 psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF »</TD></TR><TR><TD CLASS="quote">
a sensor
0-150 psi.</TD></TR></TABLE>
If you're not way out in left field, a 5 bar map sensor will usually do the trick. If you max out a 5 bar map on the exhaust then you just know you need a bigger turbo. lol
a sensor
How are you guys sourcing the pressure from the exhaust?! I would assume your standard vacuum line wouldn't do much good for this lol.
what cams are you using ?</TD></TR></TABLE>
its a custom made hi-mount manifold i made, cams are stock b16a
i use a vdo 10bar pressure sensor
Nextelbuddy
Jan 11, 2007 12:56 PM
