EG stock exhaust?
Old Aug 31, 2007 | 08:58 PM
sol_1's Avatar
Default EG stock exhaust?
Does anyone know if the is supposed to be those spring in between the axle back and the mid section of an 1992 civic stock exhaust. i recently put a stock one on and the catalic converter is about an inch short from the header. can anyone help me?
Old Aug 31, 2007 | 09:13 PM
Kelb's Avatar
if you're talking bout the springs that connect the header to your cat, then yes, they're needed, they're there because when metal heats and cools it will fluctuate in size.
There should be a slight gap between the bolt holes, but the header/cat part should sit flush.
Old Aug 31, 2007 | 09:27 PM
sol_1's Avatar
the header and cat do not sit clush and i do have the springs there. let me upload the pics.
Old Aug 31, 2007 | 09:34 PM
sol_1's Avatar
Default Re: (sol_1)
This is the cat and header.
This is the cat and mid section.
This is the mid section and axle back.
Does the mid section and axle back have the springs also? the guy i got it from had it on an 1992 SI HB and i have a DX. Is there supposed to be a slight difference or am i missing something?
Old Aug 31, 2007 | 10:05 PM
sol_1's Avatar
anyone?
Old Aug 31, 2007 | 10:09 PM
ejoner's Avatar
Default Re: (sol_1)
Your missing a donut looking gasket. go get that and guaranteed it will fit.
Old Aug 31, 2007 | 10:15 PM
sol_1's Avatar
thanks! i am guessing it is #28 on here.
http://www.hondaautomotivepart...YSTEM
Old Aug 31, 2007 | 10:20 PM
truevietluv636's Avatar
Default Re: (sol_1)
i think you installed the springs wrong from the cat to header.
Old Aug 31, 2007 | 10:26 PM
speedooo's Avatar
Default Re: (ejoner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner &raquo;</TD></TR><TR><TD CLASS="quote">Your missing a donut looking gasket. go get that and guaranteed it will fit.</TD></TR></TABLE>
look closer andc youll see that its stuck inside the collector
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by truevietluv636 &raquo;</TD></TR><TR><TD CLASS="quote">i think you installed the springs wrong from the cat to header.</TD></TR></TABLE>
yeah they go on the outside buddy
Old Sep 1, 2007 | 03:06 AM
92ehatch's Avatar
Default Re: (speedooo)
i think there are supposed to be springs on the axle back part you pictured.
also, my cat and header were about that far away as well.
i just tighted the bolt and nut as hard as i could and it drew them together
Old Sep 1, 2007 | 05:08 AM
sol_1's Avatar
thanks guys. in the pic, that is the tighest it goes. i will try to get some new gaskets then.
Old Sep 1, 2007 | 05:52 AM
Armstrong57's Avatar
The springs don't go in between the flanges. The springs should be between the outside face of the flange and the bolt head.
Old Sep 1, 2007 | 07:27 AM
sol_1's Avatar
thanks guys, i will fix it today.
Wrona
Apr 12, 2011 06:29 AM
Beau Gotti
Jan 15, 2008 12:36 PM
The G2 Racer
May 5, 2004 07:08 PM
B00ST2nR
Apr 1, 2004 12:11 PM
