wiring problem
Old Aug 30, 2007 | 11:58 AM
thresher's Avatar
Default wiring problem
95 ls with a gsr swap and im pretty sure its an ls wiring harness. so heres a picture
im trying to figure out what the green plug is for under the dizzy. it plugs up to where the cam end is but thats the wire that is hanging loose from the ecu and the vtec is not working. can someone give me an idea what that plus is for, only one wire comes off the plug and its green/black wire. im trying to use this https://honda-tech.com/zerothread?id=2074726 for reference but can anyone help me here?
Modified by thresher at 1:29 PM 8/30/2007
Old Aug 30, 2007 | 12:30 PM
coupeKID's Avatar
Default Re: wiring problem (thresher)
i believe that is your v-tec solenoid, you would need that connected to have v-tec work. as for where it goes, i will let someone else tell you in further detail.
EJ8CIVIC
Oct 4, 2015 06:41 AM
iliv2xlr8
Mar 4, 2009 06:16 PM
Acidcrakker
Nov 8, 2007 02:39 PM
allsho
Jun 14, 2007 12:06 PM
ilovemyb16a
May 18, 2006 12:58 PM
