Compression test results after 250,000 miles...
Old Jun 14, 2002 | 11:59 AM
Perfectionist's Avatar
Default Compression test results after 250,000 miles...
I just did a compression test on my '90 Civic Si Hatcback's engine. No internal work has ever been done on it, it's all stock original. The test was performed with a warm engine, all plugs removed, throttle wide open, stock air filter and intake tubing in place. Here's the results...
#1- 191
#2- 185
#3- 187
#4- 192
I was pleased with the results. Thanks for reading.
Old Jun 14, 2002 | 12:35 PM
*Boostwerks*'s Avatar
Default Re: Compression test results after 250,000 miles... (Perfectionist)
Badass!! Here's a good ol' frosty...
Old Jun 14, 2002 | 01:01 PM
Default Re: Compression test results after 250,000 miles... (Bryson)
Thanks! It could just mean there's lots of carbon build up, , but from what I could see through the spark plug holes, it didn't look bad.
Old Jun 14, 2002 | 01:05 PM
well the engine doesn't consume a lot of oil does it?
With that many miles I am very impressed!!
What type of oil do you use? normal? synthetic?
How often do you do oil change's?
Old Jun 14, 2002 | 01:11 PM
5W-30 Penzoil dino oil and Honda filter every 3500 miles. Lately it's been down about 10 ounces at the oil change intervals. I should have bought two of these cars back in 1990!!!
Old Jun 14, 2002 | 06:24 PM
Soled Out's Avatar
power, my 1.5 std. motor was the same way at 235k miles
Old Jun 16, 2002 | 03:17 PM
philly-O's Avatar
Default Re: Compression test results after 250,000 miles... (civic htchbox)
i have 2 89 hatches and took the 270k motor out af the one i am building and put it my other civic i bought with a bad timing belt and sat since 1998, and it runs great and is redlined and driven hard with over 285k on it now(all stock). i love my honda!!!
Old Jun 16, 2002 | 03:59 PM
FUP23's Avatar
New User
Default Re: Compression test results after 250,000 miles... (peichie)
whats perfect compression suppose to read ? Between 180 and 190 right ??
Old Jun 16, 2002 | 05:31 PM
primoEF's Avatar
Default Re: Compression test results after 250,000 miles... (Devin17)
those are damn good numbers
Griff
Jul 5, 2006 06:47 AM
Tony_EM1
May 26, 2005 10:34 PM
crx1856
Oct 11, 2003 11:11 AM
osuPrelude
Nov 4, 2002 08:53 PM
98civicEX
Apr 23, 2002 05:08 PM
