injector clips ?
Old Aug 29, 2007 | 02:06 PM
BMaDOHC's Avatar
Default injector clips ?
whats up guys. I just installed my new hondata s300 setup and want to install my injectors in my itr but in this months hondatuning mag they show some injector conversion harnesses that you plug into your obd2 harness and converts it to obd1 to run some rc's. this eliminates the need to cut into your factory harness. this is my first time seeing them.has anyone else seen these for sale? and by who? thanks for any info.
Old Aug 29, 2007 | 02:19 PM
Cheeze's Avatar
Default Re: injector clips ? (BMaDOHC)
here ya go!
http://www.nipponpower.com/product.phtml?p=1062
Old Sep 6, 2007 | 06:29 AM
Black R's Avatar
25 Year Member
i think len told me a long time ago that you can pull the pins on the obd2 injector clips and put the obd1 clips on without having to cut/ splice anything.....
let me see if i can find a link......
Old Sep 6, 2007 | 10:23 AM
Cheeze's Avatar
Default Re: (Black R)
Correct..All you have to do is pull the blue plug inside the injector clip. Then all you have to do is wiggle the injectors on because the slots aren't in the same location..Then I would just tie wrap them to secure it from comming loose.
Here's the Link.
https://honda-tech.com/zerothread?id=1936840
jayswizz
Feb 15, 2014 04:47 AM
rick_rabies
Jun 17, 2009 09:41 AM
all-mtr-teg
Sep 15, 2007 11:28 AM
BMaDOHC
Aug 30, 2007 12:39 AM
acman1
Apr 24, 2003 06:29 PM
