in middle of injector install, help please!!!!
Old Apr 24, 2003 | 10:09 AM
acman1's Avatar
Default in middle of injector install, help please!!!!
y wont my obd2 clips plug into my dsm injectors. i cut the rib thing out of the injector...
Old Apr 24, 2003 | 10:15 AM
boostin b16's Avatar
Default Re: in middle of injector install, help please!!!! (acman1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acman1 &raquo;</TD></TR><TR><TD CLASS="quote">y wont my obd2 clips plug into my dsm injectors. i cut the rib thing out of the injector...</TD></TR></TABLE>
they wont fit because you need obd I clips!
Old Apr 24, 2003 | 10:24 AM
acman1's Avatar
Default Re: in middle of injector install, help please!!!! (boostin b16)
noooooo, i thought as long as u shaved off the thing in the injector it would b ok...where can i get obd1 clips fast?
Old Apr 24, 2003 | 10:56 AM
98civicEX's Avatar
some autoparts stores actually have them in stock...but seeing how you're in gainsville, i'd call up all the local shops...they should have them handy.
Old Apr 24, 2003 | 11:31 AM
acman1's Avatar
Default Re: in middle of injector install, help please!!!! (98civicEX)
is there a part number or something? i went to napa and they looked at me funny and the honda and acura dealer makes u buy the whole engine harness...
Old Apr 24, 2003 | 11:32 AM
sweet's Avatar
if you trim the tabs you should be able to use the OBD2 clips with those injectors.
maybe not cause i've never actually used DSM injectors myself. i used OBD2 injectors with my OBD1 clips and they fit right in once a trimed the "tabs". if it doesn't work then i guess you'll have to check around locally to see who has the clips you need.
Old Apr 24, 2003 | 11:37 AM
acman1's Avatar
Default Re: in middle of injector install, help please!!!! (sweet)
the tabs on the clips or the injector?
Old Apr 24, 2003 | 11:51 AM
dfoxengr's Avatar
u also need resistors or the box if u dont have it already..
Old Apr 24, 2003 | 11:53 AM
acman1's Avatar
Default Re: in middle of injector install, help please!!!! (hybridvteceg)
yeah i got that, if i just cut a bunch of stuff out of my clips to make the dsm's fit, it would b ok rite?
Old Apr 24, 2003 | 11:56 AM
b18bturbo's Avatar
you need the clips if you need some we have them in stock. you have to cut and splice them into your harness
Old Apr 24, 2003 | 11:59 AM
sweet's Avatar
hmm, it's been awhile since i did that. i think it was the injector that i trimed to fit the OBD1 clips, but as i said i'm not sure about the dimensions/tabs on the DSM injectors since i've never used them. but if they just need the plastic trimed to fit the clip i don't see any harm in that. i trimed OEM injector plugs before without any problems at all.
someone else may have more insight on the DSM injectors though.
Old Apr 24, 2003 | 12:03 PM
genop's Avatar
I wouldnt cut anything on the injector itself. The clips are inexpensive, just bite the bullet and order some.
Old Apr 24, 2003 | 12:06 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acman1 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i got that, if i just cut a bunch of stuff out of my clips to make the dsm's fit, it would b ok rite?</TD></TR></TABLE>
no
you need OBD1 injectors, and cut the tab out of the injector...not the part that connects to the wire harness...
Old Apr 24, 2003 | 12:19 PM
acman1's Avatar
Default Re: in middle of injector install, help please!!!! (b18bturbo)
how much for the clips, and how long to ship?
Old Apr 24, 2003 | 12:56 PM
Trac226's Avatar
I got my clips from Sonny (user name) and they came in like 2-3 days, i'm he could ship overnight. Hmmm, too cheap to remember the price...
Old Apr 24, 2003 | 06:29 PM
scttydb411's Avatar
try going to the pull it yard on north 441 just north of 53rd. it's near sunstate recycling i think. find an older civic and cut the injector plugs off. if that yard doesn't have them if you are ever up in the atl there are yards loaded with them. if you don't get any i'll be down memorial day week end and might be able to bring some with me.
btw...the obd2 are fatter on the male side than obd1.
SiR99
Apr 29, 2006 10:18 AM
RACEPAK
Jul 19, 2005 09:51 AM
Black R
Jun 17, 2004 01:34 AM
ScrapinSi
Oct 19, 2003 03:58 PM
Babybluegsr92
Aug 15, 2001 12:45 PM
