Possible transmission problem?
Old Aug 29, 2007 | 01:02 PM
ktn048's Avatar
Default Possible transmission problem?
I own a 1996 Civic EX, recently I have noticed when I am accelerating the rpms seem to being going a bit high. I do not attempt to accelerate a lot, just a "normal" amount and the rpms are hitting almost "4".
Also, I noticed when I turn off my A/C it emits a short high pitch squeaking noise...???
Obviously I don't know anything about cars and I wanted to find out some info before I spend money at a mechanics. Any advice would be great.
Old Aug 29, 2007 | 01:06 PM
ke98248's Avatar
Default Re: Possible transmission problem? (ktn048)
Sounds like perhaps your clutch almost burnt out.
Old Aug 29, 2007 | 01:07 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ktn048 &raquo;</TD></TR><TR><TD CLASS="quote">I own a 1996 Civic EX, recently I have noticed when I am accelerating the rpms seem to being going a bit high. I do not attempt to accelerate a lot, just a "normal" amount and the rpms are hitting almost "4".
i'm taking it your tranny is an automatic. it seems about right to shift at about 4K. try replacing your tranny fluid, it should help alittle with quieter and smoother shifting. make sure you get Honda transmission fluid.
chances are your belt needs adjustiing or replacing. i would inspect the belt for dry rotts and/or cracks. if good, i would adjust it before replacing.
these are both easy maintanence step that you can do with basic tools. a repair manual wouldn't hurt.
Old Aug 29, 2007 | 01:14 PM
joe94honda's Avatar
if it is a mual transmission i would almost be positive that your problem is your clutch if automatic and it feels like it is slipping i would try a torque converter or a fluid change the air conditioner proble is most likely a belt try a new belt or some belt dressing first to see if that wont quiet it down
Old Aug 29, 2007 | 03:47 PM
adamquik's Avatar
with any noise we always change the fluid first. be amazed what a simple fluid change can do.
00EKSDN
11
May 28, 2009 11:29 AM
IMPORT_IMAGE
Jan 3, 2008 10:05 AM
snatch
Dec 13, 2005 11:23 AM
coquitlamEG
Dec 3, 2005 12:41 PM
StOnErTuNinG
Dec 26, 2004 04:57 AM
