Losing Weight in your Drag Car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 »</TD></TR><TR><TD CLASS="quote">
I use the weight watchers points, others just use slim fast 3 times a day, and others...well they are sponsored by lettuce companies and stick strictly to only lettuce.</TD></TR></TABLE>
I usually dont eat or sleep 4 days before the race because i am rushing so bad to get it done,
i.d.k. what i did from last year to this year, but somewhere my car lost 100 lbs and we ran with more fuel than normal. i know it didnt come off of my belly. we were 2650 last year, and saturday at MIR i was 2540.
he hee. j/k out came all the hvac stuff, power steering stuff, lighter battery, and my 3 piece bogarts are about 30% lighter than the 2 pieces from last year.
i thought you just get a suited up, then go sit in your car, in the sun
You ain't supposed to drink it.
Water weight lol I gained some, must have been the chicken tenders and buffalo sauce!</TD></TR></TABLE>
I am sorry, actually I gained 10 between 1st and 2cd. Must have been the amish potato salad and brats,lol!
Modified by jjspec at 3:09 PM 8/29/2007
wheels and tires!! you can shed a lot of weight by wheels alone.
dropping the exhaust and taking out the sunroof assembly can save you a good amount of weight as well.
There's quite a bit of thread on the subject of weight.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech »</TD></TR><TR><TD CLASS="quote">hit up the crack pipe for a week, and by the time u go race ,u'll save alot of weight!!!
and be wired ready to go!
coke diet works good too, but can be more expensive
</TD></TR></TABLE>and be wired ready to go!
bumper supports, sound deadening material, lighter battery, rear interior(depending on class), wheels, as stated earlier, all the extra crap you carry in the car, take a pre-game dump, if its not a spo-comp car, lexan windows, gutted doors, etc
Titanium Vtec cam cap kit. for the true baller
some of the crossmember bolts are huge
Titanium Axles saves 4 pounds
Front LCA saves 8 pounds
Rear LCA saves 4 pounds
Titanium rear LCA bolt kit saves 1/2 pound
Titanium Front crossmember kit Saves 2.5 pounds
Titanium Bellhousing bolt kit saves .6 pounds.
Total weight savings is 19.6 pounds. thats in addition to all the other mods you can do.
Modified by omniman at 9:14 PM 8/31/2007
The axle shafts we currently make fit OEM GSR CV joints (stock dimentions). i wouldnt rate them much higher than OEM. The material is about 10% stronger than the oem shaft. The end snot and the tri-pod tend to be the weaker areas.
There are many factors that cause axle breakage, some people snap stock axles with 250 hp and others have no trouble with 400 hp. Putting an accurate HP rating on them would depend on many factors.
Das Nuge
Mar 28, 2005 08:47 PM
slownslc
Jun 18, 2002 10:33 AM
