How restrictive are 3 chambers mufflers?
Old Aug 29, 2007 | 05:45 AM
Maxime's Avatar
Default How restrictive are 3 chambers mufflers?
So my 3" high flow cat. took a crap on me and I was thinking about replacing my muffler while I'm working on the exhaust system.
The police around here uses the "metal wire" technic to check of your exhaust is modified. They basicaly stick a metal wire inside your muffler and if it goes straight thru. You're busted. They don't have the equipment to test how loud your car is. So instead they nail you for the design of the muffler that is different then stock.
Anyway, I was wondering how much more restrictive a 3 chamber design muffler would be compare to my Magnaflow "WideOpen" straight thru muffler?
I'm want to get a 3" Magnaflow XL:
http://www.magnaflow.com/02pro...d=303
Any good?
Modified by Maxime at 10:06 AM 8/29/2007
Old Aug 29, 2007 | 07:19 AM
spets's Avatar
they will be more restrictive (obviously), but not as restrictive as stock...
Old Aug 29, 2007 | 07:28 AM
ragethemachine86's Avatar
Default Re: How restrictive are 3 chambers mufflers? (Maxime)
you will definitely lose a bit of power. Whats your whp? If you have a 400whp car you will lose a lot more power than on a 250whp car.
Old Aug 29, 2007 | 08:09 AM
quicksilver1689's Avatar
i ♥ snails
flowmaster's have always been good imo. only used them on some older v8 powered vehicles but they never seemed too restricitive, im suprise that your county can do that? not test db but say that it too loud? its like when cops try and say I visualyl clocked you at 44 the speedlimit is 40, its like bs lol. I doubt cops could tell 95db from 97 or vice versa.
Old Aug 29, 2007 | 04:37 PM
sc4dr's Avatar
Default Re: (quicksilver1689)
I used to run a flowmaster when I was in the 220hp range. They actually sound really good on a boosted Honda.
Old Aug 29, 2007 | 09:47 PM
Maxime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">flowmaster's have always been good imo. only used them on some older v8 powered vehicles but they never seemed too restricitive, im suprise that your county can do that? not test db but say that it too loud? its like when cops try and say I visualyl clocked you at 44 the speedlimit is 40, its like bs lol. I doubt cops could tell 95db from 97 or vice versa.</TD></TR></TABLE>
They pull you over because your exhaust is too loud but they can't give you a ticket for that because they can't prove it in a court of law. So instead they prove that your exhaust isn't stock and the way they do that is my proving the exhaust doesn't have internal chambers.
Old Aug 29, 2007 | 09:53 PM
ridin98civic's Avatar
Default Re: (Maxime)
i guess srt-4 owners are boned
also i will be using a flowmaster delta 40 on my boosted D shortly
Old Aug 29, 2007 | 10:17 PM
tokesGTR's Avatar
STFU.
Using them for the white trash sound on some older V8 cars doesn't have **** to do with a turbo 4 cylinder. You're as good as tony413.
http://www.theturboforums.com/mufflerswap.php
Blue line = flowbastards
Red/Green = Dynomax
Look at all that mid range.
Old Aug 29, 2007 | 11:36 PM
Maxime's Avatar
Most chambers mufflers on the market are built with V8 in mind.
I've read a couple of reviews and I like the Hooker Aerochambers. It's fairly cheap and it seems to flow pretty good.
But it has an aluminized finish. How well would that resist to our Canadian winters? Is it going to rust to **** after one year? lol
I should probably get a stainless steel muffler right?
Old Aug 29, 2007 | 11:39 PM
i have an aerochamber on my d right now, but its getting tossed when i boost. sounds great, but the finish is chipping, and hasnt even been through a winter yet.
Old Aug 29, 2007 | 11:44 PM
i ♥ snails
Default Re: (tokesGTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tokesGTR &raquo;</TD></TR><TR><TD CLASS="quote">
STFU.
Red/Green = Dynomax
Look at all that mid range.</TD></TR></TABLE>
wow you showed me one setup, every engine combo is different, and has different needs. for bein a big dick!
Old Aug 30, 2007 | 03:23 AM
non-VTEC's Avatar
dynomax super turbo 3" in/out here.........sounds great (quiet) and is inexpensive.
is it restrictive? probably.......do i care? not really..........420whp@17psi
Old Aug 30, 2007 | 05:23 AM
Bailhatch's Avatar
Default Re: How restrictive are 3 chambers mufflers? (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">dynomax super turbo 3" in/out here.........sounds great (quiet) and is inexpensive.
is it restrictive? probably.......do i care? not really..........420whp@17psi </TD></TR></TABLE>
thats what I have as well, with 2 18" resonators up front...it's very quiet. The muffler is actually a 2.5" muffler with 3" flared ends. My car showed no signs of choking up but it only made 300ish at the wheels at 10psi (60trim/b16). Open dump wastegate helps too. Im going to use a 3" hooker max flow once i recirc the WG and run more boost.
Old Aug 30, 2007 | 08:00 AM
B20luda's Avatar
Default Re: How restrictive are 3 chambers mufflers? (Bailhatch)
I used to run a 40 series deltaflow on my boosted prelude, 3in DP back... i was tired of the look so i swaped it to an apexi muffler, as soon as i went on the street with the new muffler i kept hitting boost cut... my previous boost setting was around 15psi... it kept hitting boost cut which was 18.5 psi... i did nothing to the boost controller just welded the new muffler on!! flowmaster on FI
Old Aug 30, 2007 | 08:50 AM
tokesGTR's Avatar
A turbo setup is a turbo setup is a turbo setup. Chambered mufflers are very restrictive, and suck *** for turbo setups. It's not hard to pick that up out of that post, a mid sized single turbo on a very mildly modified 302 is not going to create much backpressure, and ditching the crappy flowmaster already helps out tremendously.
I'm big dicks to people like you, who don't know what they're talking about and give people advice when they have absolutely zero real experience with the subject
Mr.Highlife
Apr 15, 2008 09:45 AM
GoLowDrew
Apr 19, 2006 09:18 AM
VTECTIME
Jan 15, 2003 04:20 PM
RATEDR
Jul 13, 2002 08:17 PM
