d16y7 Transmission Help?!
Old Aug 28, 2007 | 04:20 PM
peterislazyek9's Avatar
Default d16y7 Transmission Help?!
D: Hey, i don't know if this has ever been posted this help before but yeah anyways. i tried searching or help on this topic but couldn't find any. so here it goes.
My Tranny on my stock d16y7 was acting up on me making noises from the pilot bearing so i took the transmission of and put in another used transmission. i test drove the transmission and it ran flawless before i bought it. then when i took it home to install in my car everyuthing went perfect but one thing! T_T (here's the problem) I put it in first gear, and it wobbles left and right like it's in neutral. D: it accelerates on all gears and goes into all gears 1 2 3 4 5 R but when i put it in any gear like first or second it wobbles like it was in neutral. anyone know the solution to this problem? my friend told me to check the shift linkage and i'll be doing that today. thanks! for the help if any..
Old Aug 28, 2007 | 06:53 PM
slowcivic2k's Avatar
Default Re: d16y7 Transmission Help?! (peterislazyek9)
Check your shifter bushings/bolts and the spring pin that mates the linkage to the shift arm shaft. Many people place bolts in there, which results in shifter play as well..
Old Aug 29, 2007 | 12:24 AM
i'll check on that right away! thanks for the tip mr slow civic lol hopefully it's just that
Old Sep 3, 2007 | 01:04 AM
hah what do yah know. shaft play for the pin that connects the shift linkage to the transmission.....
SCMFOX
Jul 16, 2018 04:06 PM
n*werk
Feb 8, 2008 08:14 PM
honcrx91si
Aug 25, 2006 08:24 PM
cxSHOE
51
Nov 24, 2003 05:43 PM
marcin
Aug 28, 2003 03:09 AM
