Tighten the timing belt
Old Jun 14, 2002 | 07:31 AM
KoRE's Avatar
Default Tighten the timing belt
How do you tighten the timing belt on a d16z6.
Mine is loose and the belt is hittin the lower plastic cover so how would i go about and tighten it or should i get a new timing belt?
Old Jun 14, 2002 | 07:45 AM
letsride's Avatar
Default Re: Tighten the timing belt (KoRE)
Mileage?
Old Jun 14, 2002 | 08:44 AM
KoRE's Avatar
Default Re: Tighten the timing belt (letsride)
30-40k miles on the motor
Old Jun 14, 2002 | 05:33 PM
94civicx's Avatar
New User
tighten it by the timing belt tensioner. turn it clockwise like a bolt to tighten it
Old Jun 14, 2002 | 05:55 PM
hatchmobile's Avatar
Default Re: Tighten the timing belt (94civicx)
loosen the the tensioner and turn the motor over by hand w/ a 19mm wrench (turn the motor clockwise)...it can only get so tight by doing it that way. then just tighten the tensioner back to 33ft-lbs (i think...check in manual first)
[Modified by hatchmobile, 7:12 AM 6/15/2002]
Old Jun 14, 2002 | 10:09 PM
DRxCIVIC's Avatar
Default Re: Tighten the timing belt (hatchmobile)
my car just hit 100k what other stuff to i need to change out other than just the timing belt???
Old Jun 15, 2002 | 09:27 AM
letsride's Avatar
Default Re: Tighten the timing belt (DRxCIVIC)
Water pump, seals and belts!!
VegaS10
May 20, 2013 12:05 PM
WiedemannC
Dec 6, 2010 12:35 PM
slide inside
Oct 22, 2009 09:25 AM
chahsiubow
Dec 14, 2007 10:01 PM
Luserkid
Apr 10, 2003 06:41 PM
