Quick Brake Question
Old Aug 27, 2007 | 04:54 PM
eg6madness's Avatar
Default Quick Brake Question
When i swap out my stock Civic stoppers ( front and rear) for the GSR compnents ( front and rear ) do i need to get the master cylinder from the GSR ? or all i need to get is the proportional valve ?
My pedal travel is my greater and the to me it doesnt feel like it wants to stop. From all my reading i was informed that all i will need is the proportional valve from the GSR. But a guy at the local work shop told me that i need the mastercylinder not the proportional valve. Which is it?
Old Aug 27, 2007 | 05:03 PM
slowcivic2k's Avatar
Default Re: Quick Brake Question (eg6madness)
What car do you have, and what model, and what year GSR did you get the brakes from?
Proportioning valves control the rate of apply for the rear brakes, having one that has too much give will lock up the rears.
Are all the lines fully bled? Is it spongy, or simply low? Using a larger caliper piston will increase pedal effort because more fluid must be displaced to apply the same pressure to the larger piston.
Old Aug 27, 2007 | 05:12 PM
pythoner's Avatar
the master cyclinder is only 11/16 wear as a GSP is 15/16 and it moves more fluid...I am having the same problem right now
Old Aug 27, 2007 | 05:16 PM
eg6madness's Avatar
Default Re: Quick Brake Question (slowcivic2k)
they are goin on a 93 EG hatch VTi, that originally came with the D15B vtec, the car now has the B18C. The GSR brakes came off the 94 GSR ( the one with the 4 circle lights).
The pedal isnt spongy it just goes further ( simply low).
I am goin home now and i will rebleed the lines in the correct order.
Old Aug 27, 2007 | 05:17 PM
If it stays low your MC is not displacing enough fluid, and you will need to use a GSR one.
crxsiperf
May 24, 2007 11:35 AM
civicex442
Apr 24, 2007 04:37 PM
the_0ne
22
Apr 15, 2004 09:54 PM
AThiker
Mar 4, 2003 06:19 PM
