RADIATOR HELP
Hi guys i need help again just under my radiator cap and along a bit my radiator is leaking and sort of sizzling out a bit what do i do replace the radiator or will stop leak repair it or what??? whats the go ......thanks
If the radiator itself is leaking, don't use that stop leak stuff, it breaks up inside the engine and can clog other things. Check my link for our radiators
https://honda-tech.com/zerothread?id=1935810
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bomber19 »</TD></TR><TR><TD CLASS="quote">Hi guys i need help again just under my radiator cap and along a bit my radiator is leaking and sort of sizzling out a bit what do i do replace the radiator or will stop leak repair it or what??? whats the go ......thanks </TD></TR></TABLE>
Stop leak is a very very bad idea.
It sounds like you have a crack along the top end tank. My girlfriends suzuki had the same thing. You can either patch it and wait for it to crack again, or get a new rad, which I would do.
Like RCAutoworks said, he can get you one for cheap.
