RADIATOR HELP
Old Aug 25, 2007 | 06:49 PM
bomber19's Avatar
Default RADIATOR HELP
Hi guys i need help again just under my radiator cap and along a bit my radiator is leaking and sort of sizzling out a bit what do i do replace the radiator or will stop leak repair it or what??? whats the go ......thanks
Old Aug 25, 2007 | 10:03 PM
almostboostedgsr's Avatar
Default Re: RADIATOR HELP (bomber19)
replace that ***** and keep boostin.
Old Sep 7, 2007 | 04:45 PM
RCautoworks's Avatar
If the radiator itself is leaking, don't use that stop leak stuff, it breaks up inside the engine and can clog other things. Check my link for our radiators
https://honda-tech.com/zerothread?id=1935810
Old Sep 7, 2007 | 04:52 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bomber19 &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys i need help again just under my radiator cap and along a bit my radiator is leaking and sort of sizzling out a bit what do i do replace the radiator or will stop leak repair it or what??? whats the go ......thanks </TD></TR></TABLE>
Stop leak is a very very bad idea.
It sounds like you have a crack along the top end tank. My girlfriends suzuki had the same thing. You can either patch it and wait for it to crack again, or get a new rad, which I would do.
Like RCAutoworks said, he can get you one for cheap.
jorge59la
Apr 20, 2007 07:34 AM
eg6ryder
May 5, 2006 07:03 PM
FD3S
Dec 15, 2005 08:37 AM
tkHBseries
Feb 19, 2005 06:48 PM
hybridcrx
Oct 18, 2004 10:11 AM
