vtec
Old Aug 25, 2007 | 12:40 PM
Gam3_Ov3r's Avatar
Default vtec trouble
my car is not hitting vtec i have a 93 civic eg coupe wit a ls/vtec wit a chip p28
Modified by Gam3_Ov3r at 9:38 PM 8/25/2007
Old Aug 25, 2007 | 12:44 PM
97Ej6mike's Avatar
1.) Do you have enough oil?
2.) are your speed and tachometer guages working?
3.) Do you have any check engine lights?
4.) is your car warmed up to normal running temperature?
Itd be a bigger help if you actually post other info too, such as car's year, Motor, the ECU you are running, ect
Old Aug 25, 2007 | 12:50 PM
philosofy1's Avatar
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">
Itd be a bigger help if you actually post other info too, such as car's year, Motor, the ECU you are running, ect </TD></TR></TABLE>
we need more info!
Old Aug 25, 2007 | 01:42 PM
posHonda's Avatar
Default Re: (philosofy1)
more info...
or you could have a sohc and its kickin in at its hardest but you just cant feel a damn thing.
Old Aug 25, 2007 | 01:44 PM
nix94delsol's Avatar
Default Re: (iVteC_PoWeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR &raquo;</TD></TR><TR><TD CLASS="quote">more info...
or you could have a sohc and its kickin in at its hardest but you just cant feel a damn thing. </TD></TR></TABLE>
THAT hurt!
Old Aug 25, 2007 | 02:04 PM
doood's Avatar
been there done that
Default Re: vtec (Gam3_Ov3r)
try pushing down harder on the gas pedal
Old Aug 25, 2007 | 02:09 PM
RCautoworks's Avatar
Default Re: vtec (doood)
Does your engine have vtec ?
Old Aug 25, 2007 | 05:16 PM
2mansi's Avatar
i would check oil level first. If you are throwing a code i would also check that. Theres a write up in the 92-00 thread if you dont know how to check it.
Old Aug 25, 2007 | 08:14 PM
Gam3_Ov3r's Avatar
everything is koo but it throwin code #1 but i got a chip p28 n tha motor i have is a ls/vtec
Old Aug 25, 2007 | 08:15 PM
Gam3_Ov3r's Avatar
its a 93 ex coupe wit a ls/vtec
97Ej6mike's Avatar
Default Re: (Gam3_Ov3r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gam3_Ov3r &raquo;</TD></TR><TR><TD CLASS="quote">everything is koo but it throwin code #1 but i got a chip p28 n tha motor i have is a ls/vtec</TD></TR></TABLE>
Well off the top of my head, if its throwing a code regarding VTEC, such as the solonoid, then vtec will be disabled. Did vtec work previously to this problem? Did you wire VTEC yourself, and if so, are you sure the connections are secure?
Old Aug 25, 2007 | 08:17 PM
crazyguy's Avatar
Default Re: vtec (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">Does your engine have vtec ?</TD></TR></TABLE>
+1
Old Aug 25, 2007 | 08:30 PM
Gam3_Ov3r's Avatar
it a civic ex coupe it *** wit vtec already wired
Old Aug 25, 2007 | 08:36 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gam3_Ov3r &raquo;</TD></TR><TR><TD CLASS="quote">it a civic ex coupe it *** wit vtec already wired</TD></TR></TABLE>
Ok well that helps us out some more.
For future reference, post up all this type of info in your first post when you do new threads.
Did you go thru my first respose list of things to check?
That your speedo and tach guages work properly?
YOu have enough oil in the motor?
you car's temp guage reads correctly, and that you are trying this once it has left the mark "c", under normal running temps?
Ron454321's Avatar
So damn hard to read your posts. The code #1 is for Oxygen Sensor. Check wiring first then replace if that doesn't help. From my knowledge you will not "hit" vtec while you are showng a CEL. Read the FAQs next time, much easier.
Old Aug 25, 2007 | 08:41 PM
97Ej6mike's Avatar
Default Re: (Ron454321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ron454321 &raquo;</TD></TR><TR><TD CLASS="quote">So damn hard to read your posts. The code #1 is for Oxygen Sensor. Check wiring first then replace if that doesn't help. From my knowledge you will not "hit" vtec while you are showng a CEL. Read the FAQs next time, much easier.</TD></TR></TABLE>
Somewhat accurate, only for certain ones, mainly VTEC CEL's themself, or other very vital sensors. Things like o2 sens, secondary o2, IAC, iat, ect, at least for me, have not disabled VTEC.
Old Aug 25, 2007 | 09:03 PM
Gam3_Ov3r's Avatar
alrite thanks
Old Aug 29, 2007 | 04:45 PM
eg2GAMEOVER's Avatar
New User
Default Re: vtec trouble (Gam3_Ov3r)
Fucc , just tell chad to fix it dawg...hah check out justins picture ...this is Pec
NaisBest
26
Jun 10, 2008 11:23 PM
Stray
11
Mar 25, 2007 08:23 AM
jonrv13@
Oct 14, 2006 04:53 AM
jeys_si
12
Oct 31, 2005 11:32 AM
Hey_crx
13
Feb 10, 2005 11:09 AM
