NO VTEC!!!!!!
NO VTEC!!!!!!
just swapped my car and vtec does not engadge the check engine light comes on and throws codes for the tps and the map sensor so i changed both sensors and the light still comes on after i get on it for awhile and vtec does still not engadge does anyone have any suggestions?
Re: (95vxtealhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95vxtealhatch »</TD></TR><TR><TD CLASS="quote">What year civic and trim level is it? What motor are you running and what ECU are you running?</TD></TR></TABLE>
i just said that
i just said that
Re: (NaisBest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NaisBest »</TD></TR><TR><TD CLASS="quote">its a 93 dx hatch it had a 1.5 non vtec motor the motor in it now its a ctr with a chipped p28 it used to be auto too</TD></TR></TABLE>
you need a obd2 vtec harness with a obd1 conversion harness to hook up to the ecu
Re: (nicks-eg6)
yeah but i pinned the wires into the obd1 harnes that went into the ecu it doesnt throw codes for the selenoid at all if i disconnect the vtec pressure switch it will then throw a code for it..........do i still need that conversion harness?
Re: (95vxtealhatch)
i printed out a sheet of paper with that told me witch wire goes where on the connector for the ecu and went off that and then got the pins and put the wires where the diagram told me for vtec
Re: (NaisBest)
like the harness had no vtec b4 so i put the wires into the ecu plug where it told me i got the write up on how to do it on honda-tech but i cant find the thread right now
Re: (NaisBest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NaisBest »</TD></TR><TR><TD CLASS="quote">like the harness had no vtec b4 so i put the wires into the ecu plug where it told me i got the write up on how to do it on honda-tech but i cant find the thread right now</TD></TR></TABLE>
IMO.... dont be cheap, i think your vtec isn't working because it isn't pinned right. i would buy all the right stuff so this doesn't happen again
Re: (NaisBest)
ok i bought all the pins with like 6 inches on them spliced them soldered them then put them where vtec would be pinned for the vtec model eg i don't understand how that's cheap or not the right way? explain im lost ha
did you reset your ECU after swapping the sensors out? under the hood its the only 7.5 amp fuse next to the battery under the lid of that black box.
Its possible you ran the vtec wire incorrectly too.
Re: (95vxtealhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95vxtealhatch »</TD></TR><TR><TD CLASS="quote">I think you have over looked something. Go recheck everything, and make sure your harness actually hooked into the vtec solenoid.</TD></TR></TABLE>
i don't think the non-vtec harness came with the hook up to the solenoid
Re: (95vxtealhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95vxtealhatch »</TD></TR><TR><TD CLASS="quote">What engine is this again? I don't recall the civic ever producing a civic type-r, which is what ctr means to me.</TD></TR></TABLE>
if i am right then the b16b from the jdm civic type r, which is 96 -99 i think.
Oh right i forgot about the 6th gen type r. So you got an obd2 motor wired into an obd1 car. I think you need that conversion harness. i also think jdmshit.com sells them.
Re: (95vxtealhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95vxtealhatch »</TD></TR><TR><TD CLASS="quote">Oh right i forgot about the 6th gen type r. So you got an obd2 motor wired into an obd1 car. I think you need that conversion harness. i also think jdmshit.com sells them.</TD></TR></TABLE>
thank you..
thank you..
Re: (nicks-eg6)
well i rewired it so it has an obd 2 distributor it has an obd1 alternator and obd2 itr injectors and those are the only things i can think that needs to be obd2 im pretty sure the selenoids are the same tho and yeah its a b16b obd2 motor from the ek but what else would need to be obd2? especially if your just going to convert it to obd1 anyways
