problems with plastigauge and bearing selection
Old Jun 13, 2002 | 08:08 PM
Wicked Sol's Avatar
New User
Default problems with plastigauge and bearing selection
I just droped in a used motor I bought and I'm getting an oil light after the car warms up. I'm checking the clearance in the main and rod bearing but I'm having some problems I think.
Every rod and main caps #'s 2,3 and 4 are all coming out .003". I didn't check # 1 and 5 mains yet. I'm not sure what I could be doing wrong. I cut a piece of plastigauge put it in the center of the bearing and torque it down then pull the cap off and read it. I'm using the green .001-.003 plastigauge.
I have the following rod bearing installed.
#1- Green
#2-brown
#3-brown
#4-couldn't tell
letters on the crank starting at the pulley. C C C B
Mains
#2-yellow
#3-black
#4-green
#'S On the crank starting at the pulley 3 2 4 3
Letters on the block starting at the flywheel. B B C B B
I have Eagle rods and Arp rod bolts. The #1 and #4 rod bolt were torqued down to 33 ft lbs when I first got the motor but were torqued to 28 when I did the gauging.
I'm told I need to replace the 2 set of rod bolts that where over torqued because of stretching but could this affect the clearance measurement?
Old Jun 13, 2002 | 08:43 PM
1 2 NV's Avatar
Default Re: problems with plastigauge and bearing selection (Justa4)
if i remember correctly all eagle rods r #3 rod bearings, then get thickness based on stock crank #s. if it wasnt for the fact that its nightime and im naked, id go get my service manual to help ya out. but it will have to wait till tomorrow.
Old Jun 13, 2002 | 08:44 PM
earl's Avatar
.003 sounds too loose for good oil pressure. .0015 to .0017 should be the area you are looking for. Perhaps it's time for a new set of bearings. Also check the oil pump to see if it is worn out. Problem could be there also.
Old Jun 13, 2002 | 09:32 PM
B19CivicHB's Avatar
Default Re: problems with plastigauge and bearing selection (earl)
get a set of ACL bearings from Earl or Rocket (both on this board). Standard sizes too.
Old Jun 14, 2002 | 10:28 PM
Wicked Sol's Avatar
New User
It seems strange that all the clearances where all .003 that I measured plus the motor was just rebuilt not long before I bought it. Also the #3 main bearing is already black and thats the largest bearing thats listed for that journal letter.
I could understand rods 1 and 4 being out of spec because of the bolts being stretched but not the rest of them.
I going to mic the crank and see what I get but I don't have any way to measure the rods. Does anyone know what the spec is for eagle rods and what the thickness is for each color of rod bearing?
Is there any way to tell if I really did stretch the rod bolt?
No need to run around naked in the middle of the night. I won't get to this until Saturday night. But I appreciate the thought.
Old Jun 15, 2002 | 03:15 AM
Chiovnidca's Avatar
A black bearing is not a good sign. It's black because it got really hot. Probably from lack of lubrication. That crank journal is probably chewed up too. Was the engine knocking?
Old Jun 15, 2002 | 03:37 AM
Wicked Sol's Avatar
New User
Default Re: problems with plastigauge and bearing selection (Chiovnidca)
Sorry I ment it had a black color code. The bearing it self is normal color and wear.
Old Jun 15, 2002 | 09:23 AM
Chiovnidca's Avatar
Sorry, I misread your post.
orod917
Engine Machining & Assembly
May 13, 2019 10:38 AM
95hondasedan
Nov 17, 2014 07:45 AM
AssPenny
13
Feb 22, 2014 07:51 AM
viera
Feb 19, 2010 12:09 PM
B18EG6
Jun 30, 2004 04:15 PM
