ECU chipped VS. NOT
Old Aug 23, 2007 | 06:59 PM
92yellowEG's Avatar
Default ECU chipped VS. NOT
SO what do people think what is better chipped or not?
Obviously depneds on mods and what not,
but what about the pro's and con's of putting a chip in your ECU?
Will it cause damage to your ECU or other components or not?
Is it worth the money?
Old Aug 23, 2007 | 07:00 PM
nix94delsol's Avatar
Default Re: ECU chipped VS. NOT (92yellowEG)
well what are you doing...it depends on the mod, if your gunna put an air intake and exhaust header on your d15b7 dont chip it
if your gunna turbo your built k20 then you may want to think about it
Old Aug 23, 2007 | 07:06 PM
BlackoutVTi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92yellowEG &raquo;</TD></TR><TR><TD CLASS="quote">SO what do people think what is better chipped or not?
Is it worth the money? </TD></TR></TABLE>
I'd prefer either a tuned, or stock ECU. No need to get, say, a "Skunk2" chip off eBay. I'd stay away from generic basemap chips altogether.
If you have extensive internal mods, a bigger, more modern engine, and/or an F/I setup, I'd definitely suggest a chipped and tuned ECU.
Old Aug 23, 2007 | 07:29 PM
SkankyEJ7's Avatar
Default Re: ECU chipped VS. NOT (nix94delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi &raquo;</TD></TR><TR><TD CLASS="quote">
If you have extensive internal mods, a bigger, more modern engine, and/or an F/I setup, I'd definitely suggest a chipped and tuned ECU.</TD></TR></TABLE>
he speaks the truth
plus when you remove the j1 it goes back to being a stock computer sot he whole process is reverseable
Old Aug 23, 2007 | 07:33 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nix94delsol &raquo;</TD></TR><TR><TD CLASS="quote">well what are you doing...it depends on the mod, if your gunna put an air intake and exhaust header on your d15b7 dont chip it
if your gunna turbo your built k20 then you may want to think about it</TD></TR></TABLE>
COrrect me if im wrong, but using K'pro, it wouldnt be considered chipped, wouldnt it be considered a form of an EMS or piggyback when you do it with a K series?
Chipped would be like a p28 for any 92-00 civic, with companys such as Crome and uberdata.
Just my $0.02
Modified by 97Ej6mike at 8:57 PM 8/23/2007
Old Aug 23, 2007 | 07:42 PM
SkankyEJ7's Avatar
Default Re: ECU chipped VS. NOT (97Ej6mike)
actually kpro uses a rsx ecu thats been modified with a flashable rom board or something, so i guess you could call it a "chipped' ecu
Old Aug 23, 2007 | 07:50 PM
97Ej6mike's Avatar
Default Re: ECU chipped VS. NOT (SkankyEJ7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">actually kpro uses a rsx ecu thats been modified with a flashable rom board or something, so i guess you could call it a "chipped' ecu </TD></TR></TABLE>
Yea, i was debating that. You could call it that then i guess. I just wasnt totally sure, so i thought id put it out there.
Old Aug 23, 2007 | 07:52 PM
t0p_sh0tta's Avatar
There are no "cons" to running a "chipped" ecu. If you have the suppoting mods, you'd be a fool to use the stock ECU.
p.s. bullshit eBay moogen, spork, etc. chips are exempt from this statement.
Old Aug 24, 2007 | 01:00 PM
92yellowEG's Avatar
ok, thanks for all the feedback. I had herd to many things from people who had no clue so I wanted to find out for sure.
I have all th basic bolt on's (intake, full exhaust, short throw, clutch) and wasn't going to chip it but thought I'd check anyway.
Old Aug 24, 2007 | 01:02 PM
Default Re: (92yellowEG)
What are they bolted onto?
SOHC = Tune not needed
K20 (one of the good ones) = Tune would be good
Old Aug 24, 2007 | 01:10 PM
92yellowEG's Avatar
Oh yea, JDM SOHC VTEC
Old Aug 24, 2007 | 01:13 PM
Well, good call on not going with a chip/tune yet. Write back when you go turbo.
Unseen Racer
Aug 29, 2008 08:37 AM
pxsx
Sep 26, 2007 07:29 PM
grimsey
May 3, 2005 03:27 PM
92LsTegra
Jan 21, 2005 05:46 AM
bearboy80
20
Sep 17, 2003 02:20 PM
