94 ex coupe into 94 cx hatch
will the rear trailing arms with disc brakes from a 94 civic coupe fit a 94 cx hatchback with drums and if so any modifications needed ??? also the doors the ex are all power ,will i be able to swap the doors too?
Does the coupe have ABS? Im assuming its an EX with the rear disc option? I dont remember if the rear disc only came as an option itself or with the ABS
Someone please chime in and educate me on this, but I believe I heard that if you are doing a rear brake swap and your car is Non-ABS, that the disc assembly must be Non-ABS as well.
Like I said, someone please chime in and correct this if it is indeed not true.
It you said that the coupe was non-abs I would have said that it would be a direct change over, but since its ABS to Non-ABS im a little hesitant to give a definite "yes its possible"
The EX doors will swap over, but you will need the floor harness as well. Try and search the FAQ, I believe there may be a write up on how-to.
EDIT: Found it ---> <FONT COLOR="red">https://honda-tech.com/zerothread?id=1065575</FONT>
here you go for the write up on the doors.
http://repo.jackmoves.com/v/erik/albun31/albun42
if you don't want the doors send it to me. haha. as for the brakes i'm not too sure about the abs part, but i know that the front brakes on the 94-95 has a bigger rotors.
ej6joe
27
Feb 17, 2008 05:10 PM
supdawg2
Aug 26, 2004 08:45 PM
SpoonFedHatch
Dec 10, 2003 09:48 AM
DavidTurbo
Mar 24, 2003 06:14 AM
