Rear disc brakes on my 94 CX can anyone help
I want to put disc brakes on my 94 CX and was wondering how I go about doing it, easiest way. I know the EX comes with them and the Integras and Si CRX's I'm sure the ones off the EX would be easiest but if I can't get my hands on those what would be my next best bet. Do I have to change the whole arm? Any help is apreciated. Thanks :
Re: Rear disc brakes on my 94 CX can anyone help (DavidTurbo)
Use the search, you should turn up a few topics, it was discussed just recently. EX do not have rear discs.
[Modified by piscorpio, 10:28 PM 3/22/2003]
Re: Rear disc brakes on my 94 CX can anyone help (CXHatchback)
the abs ones did.
Re: Rear disc brakes on my 94 CX can anyone help (piscorpio)
I stand corrected. Do you know if only the EX came with ABS? Apparently not all ABS equipped Civics had rear discs.
Lets get this straight......The
EXA coupe had rear disc's.
It was an option, but did not come
standard. It was standard on the
si.
si.
Go for the rear setup off of a 94-01 integra. that should be the easiest to find. Also get the mc/booster from an 88-91 civ sedan. Search for "easiest master cylinder" and you should find the thread that explains this. You will also need the 4040 prop valve from the teg.
HatchAttack242
13
01-20-2003 11:18 AM
